head gasket
Submitted: Friday, Dec 12, 2008 at 17:40
ThreadID: 64213 Views:2376 Replies:8 FollowUps:1
Does anybody know why or what i did to cause my patrol 4.2td to crack its head gasket in 2 places. It was getting hot only on long hills apart from that always ran below half on temp guage.
Reply By: Fiona & Paul - Friday, Dec 12, 2008 at 18:00
Water or oil shortage at a rough guess.
Paul H
OZ Downunder
AnswerID: 339407
Reply By: Member - Kiwi Kia - Friday, Dec 12, 2008 at 18:17
How many km's ?
'Lugging' an engine on long hill climbs will not help. Avoid using overdrive or a high gear if you are doing a long climb or pulling a heavy load.
AnswerID: 339410
Reply By: Dunaruna - Friday, Dec 12, 2008 at 19:21
Heat, heat and heat are the main causes for cracked head gaskets.
It only takes 5 seconds, then it's too late.
AnswerID: 339414
Reply By: Foxhound (WA) - Friday, Dec 12, 2008 at 19:33
Is the head cracked or is the head gasket blown? Foxhound (WA)
AnswerID: 339415
Reply By: Graham & Lynne - Friday, Dec 12, 2008 at 19:34
spudnit
do you have a cracked head?
or blown head gasket?
From Graham
AnswerID: 339416
Reply By: spudnit - Friday, Dec 12, 2008 at 21:59
Head gasket gone in 2 places. Head ok Valves needed doing. Ive done 194000 kms. I tow a 23ft van . I believe im light on the right foot and only tow in 4th gear never overdrive. It was fine then all of a sudden was getting hot.
AnswerID: 339433
Reply By: SPRINT-GTO - Friday, Dec 12, 2008 at 22:08
Blocked or faulty radiator??
AnswerID: 339436
Reply By: mr fixit - Saturday, Dec 13, 2008 at 07:23
Well you answered your own question. . . ..
There is no doubt that getting hot has blown the gasket. . . .It maybe started from a small leak that was un-noticed and then got hot because of low coolant, or a blocked radiator or faulty fan hub (very common) but for sure if you kept driving it up long hills and it was getting hot that is what has blown the gasket.
I have been in the trade for over 45 years and can now say that MOST head gaskets are blown by the drivers.
If it gets hot or has a coolant leak get it fixed . . . .don't drive it.
Doug
AnswerID: 339455
Follow Up By: spudnit - Saturday, Dec 13, 2008 at 09:21
Hi Doug
Thing is it never used cookant or oil . It was also the last thing the person fixing the car looked for as he services the car and knows it well. Everything else was replaced then head off to find it
Yes radiator that was due for its 12mth service in 2 weeks time was blocked so replaced. But it was still full of coolant . Oil and coolant checked all the time. Car serviced every 5000kms never miss.
FollowupID: 606981
