Garmin power
Submitted: Saturday, Dec 13, 2008 at 11:04
ThreadID: 64225 Views:3075 Replies:6 FollowUps:8
Have looked and looked ,cannot find in spec sheets , Garmin gps comes with cig plug for power , so the question is does the unit run on direct 12v or does the cig plug reduce to a lower voltage , or ? plan is to direct wire to aux bat via suitable fuse , neater and frees up socket.
Reply By: Member - Andrew (QLD) - Saturday, Dec 13, 2008 at 11:31
It depends on what the model GPSr is....older models like the etrex (non "x" versions), emap etc reduced it to around 3v, however "most" of the other handheld models would accept from 8-36v.
What is the model Axel?
Andrew
AnswerID: 339481
Follow Up By: Axel [ the real one ] - Saturday, Dec 13, 2008 at 19:05
Nuvi 260
FollowupID: 607057
Follow Up By: Member - Andrew (QLD) - Saturday, Dec 13, 2008 at 19:51
By the looks of it, the Nuvi 260 uses a miniUSB lead, so it will require 5vDC to power/charge the unit. The issue to wathc if you are using a non-genuine miniUSB lead plugged into 12v is that it can handle 1A, as the unit draws 5 watts maximum.
See here for a direct wire setup ==> http://www.gilsson.com/garmin_gps/cables/GUSB5V-B.htm
The answer is that the plug is needed to reduce the voltage down to 5vDC :-)
Hope that helps Axel.
Andrew
FollowupID: 607064
Follow Up By: Axel [ the real one ] - Sunday, Dec 14, 2008 at 09:21
Thats the answer needed , thank u.
FollowupID: 607151
Reply By: Member - reggy 2 (VIC) - Saturday, Dec 13, 2008 at 16:02
hi axel
my garmin 72 runs 8-35vdc which has basic 12v plug
u can find in guide book
cheers reggy2
AnswerID: 339517
Reply By: Zukscooter - Saturday, Dec 13, 2008 at 17:46
Why not go out & purchase a multiple socket power board for the said cig. socket won't cost arm or leg.
Bob.
AnswerID: 339526
Follow Up By: Axel [ the real one ] - Saturday, Dec 13, 2008 at 19:03
That defeats the purpose of the exercise , would only create more clutter , the whole point is to hide /eliminate from view wiring.
FollowupID: 607056
Reply By: Pat Malone - Saturday, Dec 13, 2008 at 18:28
plug the adaptor into the cig socket and then test the end that goes into the gps with a multi meter to see what it puts out
AnswerID: 339535
Reply By: Shaker - Saturday, Dec 13, 2008 at 23:52
According to Google......
According to Garmin, charging your GPS can be done with any of 3 ways: 1. AC wall charger > 5v 1amp 2. DC car charger 3. USB connection to a personal computer. Bear in mind that all computer USB ports have a maximum power output rating of only ½ amp (500 milliamps). When you connect the Garmin GPS to a computer USB port, it identifies the lower amp output and switches to a 500mA computer connect mode.
It appears as if the plug does reduce the voltage, maybe you could just plug it into an inline socket under the dash that is wired as you suggested?
AnswerID: 339586
Reply By: Skippy In The GU - Sunday, Dec 14, 2008 at 00:05
You will find you can only charge the Nuvi units by placing it into it's cradle otherwise it thinks it's accessing the mass storgae drive.
AnswerID: 339587
Follow Up By: Axel [ the real one ] - Sunday, Dec 14, 2008 at 09:24
Wrong , cradle has nothing to do with charging in the 260.
FollowupID: 607152
Follow Up By: Member - Andrew (QLD) - Sunday, Dec 14, 2008 at 10:00
Axel, it is something worth exploring. It may not be the cradle per se, rather the type of USB lead that Garmin use for some of the Nuvi's and other types including my Oregon.
If a "normal" miniUSB lead is used on my Oregon, the device will ask if it wants to go into mass storage device mode every time it is plugged in, which get rather annoying after a while. The proper leads have pins 4 and 5 bridged together to allow the GPSr to recognise this and go straight to normal mode.
Gilsson leads, a non genuine lead, usually take this into account, however i cannot be sure i they all do. Brian from GPSOZ might be able to help more. I bought a Gilsson plug-in lead from JA-GPS which is setup to act like a Garmin version.
With a full battery, you could try another non-garmin miniUSB lead on the device, if you have access to one, to see what the effects are. I'm not sure how the Nuvi 260 handles the situation, and what display mode will be shown.
Pulling the Garmin plug apart, soldering on some leads, sealing the regulator setup in a small box, may be the easiest and cheapest way of accomplanishing a permanent setup in your vehicle.
Andrew
FollowupID: 607162
Follow Up By: Old Greasy - Sunday, Dec 14, 2008 at 19:49
Andrew, I have the Nuvi 250W and I use a 240V 150mAcharger which breaks it down to 5.2VDC. and 500mA
Have used a usb cable that came with a walkman with no problems and the cigarette lighter connection which came with the unit so it is pretty obvious that the car lead is knocked back to 5.2V.
Old Greasy
FollowupID: 607258
Follow Up By: Member - Andrew (QLD) - Monday, Dec 15, 2008 at 09:15
Thanks for that Old Greasy :-)
Andrew
FollowupID: 607338
