oil light
Submitted: Saturday, Dec 13, 2008 at 18:17
bazza j
hi need help !wallet nearly empty.jackaroo 2000se u8 auto t/d 1100klm intercooled .problem oil can & oil pressure gauge not responding at start up only occures when car sits for a time say 2to3 days re start every things is working ok ,,over night starts ok . no engine noise (only usual diesel noise)oil pressure has been tested report said a tad better than recomended as i had busted turbo a wee while ago dont want enother. oil pressure unit replaced with a newey on speck but did not solve the issue i am using the recom oil would a thicker grade help i am told a pump in the sump could have a fracture oil returning back down lines ! as you can gather i no nothing i .again i have a roughprice to replace pump some where 2.grand hope some 1 can help cheers Barry
Reply By: Willem - Saturday, Dec 13, 2008 at 18:26
Barry
I had the same thing happen to my GQ in 2005 while on a trip to WA. Couldn't find anything wrong either.
So I disconnected the oil sender for about a year. After reconnection it has worked like a charm and I have done another 80,000km since them.
339534
Reply By: mike w (WA) - Saturday, Dec 13, 2008 at 19:07
Have you tried changing oil filter brands? Seems to be a bad batch of them out there at the mmoent. Good friends Iof
mine had exact;y ther same problems you are describing. Replaced both filters with a different brand and no problems since.
Cheap and simple option to look at first.
339544
