oil light
Submitted: Saturday, Dec 13, 2008 at 18:18
bazza j
hi need help !wallet nearly empty.jackaroo 2000se u8 auto t/d 1100klm intercooled .problem oil can & oil pressure gauge not responding at start up only occures when car sits for a time say 2to3 days re start every things is working ok ,,over night starts ok . no engine noise (only usual diesel noise)oil pressure has been tested report said a tad better than recomended as i had busted turbo a wee while ago dont want enother. oil pressure unit replaced with a newey on speck but did not solve the issue i am using the recom oil would a thicker grade help i am told a pump in the sump could have a fracture oil returning back down lines ! as you can gather i no nothing i .again i have a roughprice to replace pump some where 2.grand hope some 1 can help cheers Barry
Reply By: Member - 1/2A - Saturday, Dec 13, 2008 at 18:54
Sounds like you have a dry joint in your instrument panel. Pull the panel out and using a magnifying glass check the solder joints on the instruments that don't work, if two of the gauges are faulty it will most likely be the return path, use the magnifying glass to look for a crack in the solder.
339541
Reply By: Mikelb - Saturday, Dec 13, 2008 at 20:52
It could possibly be the bracket on the oil pick up broken. Holden has a modified one with a stronger tag for the locking bolt. Do a Google for the Jackaroo
forum It comes up as a fairly common fault. My jackaroo did 200000kms but that fault didn't arise.
339559
Reply By: Mikelb - Saturday, Dec 13, 2008 at 21:05
The website that may help is Australia4wd.com and look in the section Jackaroo technical 4JX1 3.0 TDI
339560
Reply By: disco driver - Saturday, Dec 13, 2008 at 23:15
Hi Bazza,
If the oil pressure has been tested and is within specification there is obviously nothing wrong with the oil pump.
Therefore there is no point in changing to a higher viscosity (thicker) oil.
Have you changed the oil filter recently?
Some oil filters do not have anti drain valves in them and all the oil can drain back into the sump over a period of a day or so.
If the oil light and pressure gauge respond in 15-20 seconds I don't think you have a problem worth worrying about.
Just do not rev the motor or drive off till all the lights go out.
Otherwise there are two likely suspects, oil pressure sender, which you have tried, or a fault in the oil pressure gauge and/or the warning lamp electrical connections.
As a previous reply suggests try looking for a 'dry' electrical connection on those two instruments or even a faulty eatrh connection somewhere in the system.
Unfortunately poor earth connections can be a right pain in the proverbial to track down. A test light may help.
Good Luck
Disco.
(who's LandRover does exactly the same thing)
339583
Follow Up By: RV Powerstream P/L - Sunday, Dec 14, 2008 at 06:42
Definately do not change to a heavier oil as the injectors are oil pressure activated and a lot of problems arise form people using the wrong oil.
There are two filters one for main oil and a secondary for the injectors.
Sensors are a problem and oil ingress into the wiring loom and most people chase thier tail trying to find the problem which can be extremely costly with a negative result.
Ian
607129
