navigation gps
Submitted: Saturday, Dec 13, 2008 at 21:16
ThreadID: 64242 Views:2794 Replies:5 FollowUps:11
best gps to connect to laptop for moving mapping
thanks tom
Reply By: On Patrol & TONI - Saturday, Dec 13, 2008 at 21:29
tom
A usb mouse antenna is the best, and most give yo 22 channels, morethan most GPS units. The antenna will set you back between $85-$110. Antenna
Cheers, Colin.
AnswerID: 339564
Follow Up By: On Patrol & TONI - Saturday, Dec 13, 2008 at 21:30
Sorry read 20 channels
FollowupID: 607093
Follow Up By: Member - Mick O (VIC) - Saturday, Dec 13, 2008 at 22:05
Totally second what Colin has said. Mouse GPS receiver like the BU-353. I've been using mine with both Trackranger and Ozi. Works exceptionally well.
Cheers Mick
FollowupID: 607098
Follow Up By: Member - JohnR (Vic) - Saturday, Dec 13, 2008 at 22:42
The GPS Mouse mentioned above is pretty good but if your laptop had Bluetooth, a Bluetooth GPS can connect without wires connecting the two. There are heaps of those around now too, using 20 channel SirF chipsets and all.
FollowupID: 607103
Follow Up By: On Patrol & TONI - Sunday, Dec 14, 2008 at 08:58
John R
True no wires, however each and every bluetooth device needs batteries that have to be carried and more importantly have to be disposed of safely.
Also the long term cost is a concideration with batteries, that can add up.
And it's a bummer if you need a couple of batteries in the Deasert 400km from a shop. JMHO mate,
cheers Colin.
FollowupID: 607140
Follow Up By: age - Sunday, Dec 14, 2008 at 09:05
On Patrol and TONI
Re your comment about Bluetooth GPS and batteries - is simply not right. Many Bluetooth GPS's these days come with a rechargeable Li battery - ie Garmin GPS10 uses a common Nokia phone battery, easily replaced if needed and recharged or run via 240v wall pack or 12 volt plug all supplied with the kit.Mine gets about 10 hours from a charge and recharges in about 2 hours.
A
FollowupID: 607143
Follow Up By: On Patrol & TONI - Sunday, Dec 14, 2008 at 09:17
age
my comment was about bluetooth devices in general, not just gps, and it remains correct. Your gps may be an exeption, but not ALL are.
Cheers, Colin.
FollowupID: 607148
Follow Up By: On Patrol & TONI - Sunday, Dec 14, 2008 at 09:27
To all reading this thread,
A GPS10 costs $269, the antenna mouse costs $85-110.
A cable device that needs no battery & saves you $170+ no comparison.
Colin.
FollowupID: 607154
Follow Up By: Member - Andrew (QLD) - Sunday, Dec 14, 2008 at 10:18
20, 22, 30 channels is irrelevant.....
Andrew
FollowupID: 607167
Follow Up By: age - Sunday, Dec 14, 2008 at 11:18
On Patrol and Toni
I got my GPS10 (non bundled with software) for $117 delivered from Expansis in Melb to Brisbane 6 months ago. Look on Ebay there are plenty of Li-ion battery bluetooth GPS's for under $100
And agree with Andrew re channels - have a look at the satellite orbit path for the satellites above Australia and we would be lucky to have more than 12 at any given time in a usable spot for sound 3D fixes
A
FollowupID: 607176
Follow Up By: On Patrol & TONI - Sunday, Dec 14, 2008 at 13:25
Congratulations.
FollowupID: 607187
Follow Up By: Member - JohnR (Vic) - Sunday, Dec 14, 2008 at 14:59
OP TONI, I have not paid over $100 for either of the two Bluetooth GPS I have bought. Nor have I bought a battery. The newer one has a phone battery and has a 5v charger that I have unbundled and have through a switch supplying power from the roof circuitry in the car, so no wires, no clutter and the powered LED I can see when I need. Heaps better than a wired mouse GPS.
Andrew, I agree that 20, 22, 30 channels are pretty irrelevent but having operative quality information isn't. I am more interested in 12 solid channels of data than getting a maximum of eight that was the case in the past. I know I can get to see what side of the road my car is on rather than one of the roads of a dual carriageway. The more channels of quality data, the more likely hood your position is correct on the GPS.
After all of that, I have now gone integrated and the Bluetooth is superfluous, but not in this discussion.
FollowupID: 607197
Reply By: Zebra400 - Sunday, Dec 14, 2008 at 05:22
Until recently, I have been running a Garmin GPS11+ with an after market high gain external antenna.
When we added autorouting SW to the laptop, we needed 2 GPS's, one for Ozi and one for the autorouting SW.
I decided to get a GlobalSat BU-353 USB GPS receiver from GPSOz. Woh, was I impressed. It saw more satelites with a stronger signal on each one. And the new GPS was sitting on the dash of our cruiser. Gee, its very impressive.
Impressed so much, I have decided to upgrade the 11+ with another GPS mouse. Hopefully it arrives this week.
Just one thing about GPS mouse, if you want to go bushwalking, it is no good as it does not have a screen to display your position. You would have to carry a PDA or similar to view your position.
Laurie
AnswerID: 339596
Reply By: Rossc0 - Sunday, Dec 14, 2008 at 14:43
As most have said a usb gps mouse is best for this or if you want a permanent mount then on of these:
GlobalSat MR-350
I have one of these mounted on the 4x4 (which has a vehicle PC) and a
GlobalSat BU-353
for use with the laptop.
Ross
AnswerID: 339684
Reply By: Skippy In The GU - Sunday, Dec 14, 2008 at 15:03
I don't know about you guys but having a laptop on 100% of the driving time is a pain,
My recommend either get a REAL GPS Garmin, Magellan with a map display and you can have it auto routing or have the arrow pointing in the direction to where your going and you can easily connect a usb lead and have your moving maps going on the laptop.
Another idea is have a bluetooth data logger GPS , this can log your breadcrumbs while your laptop is switched off and just upload if you get lost, the garmin and magellan can do this too but mainly upto 10,000 track points
As far as I know most Bluetooth GPSr can run rechargeables andis supplied with a 12v charger , Now who would travel outback without spare batteries, that will be like not filling up your fuel tanks when you go away.
AnswerID: 339688
Reply By: Member - tom and roslyn (QLD) - Sunday, Dec 14, 2008 at 21:52
thanks all for the information
think will try gps mouse receiver
tom
AnswerID: 339755
