Patrol Vibration
Submitted: Sunday, Dec 14, 2008 at 22:03
Dune Climber
Hi all, hope someone can help with some advice. My GU 4.2TD has developed a bad vibration between 85kmh & 100kmh. Have changed wheels/tyres, replaced universals, balanced tailshaft, checked bushes,
suspension etc all without any improvement.
Vehicle is 2000 model with 120000k's. Has OME with 2in lift. Any ideas appreciated.
Reply By: Member - Dogman (WA) - Sunday, Dec 14, 2008 at 22:13
Have you swapped the front ones around only?
339760
Follow Up By: Dune Climber - Monday, Dec 15, 2008 at 21:03
Swapped all 4 around 2 at a time with 2 spare rims and tyres. Currently running original steel rims with BFG A/T's. Am going to try with set of alloys
607437
Reply By: Member - Lionel A (WA) - Sunday, Dec 14, 2008 at 22:25
DC, Once you have exhausted all the obvious stuff, I would look at having a compression check done.
Having said this of course, if a cylinder was down it would be more rev related than speed.
Cheers...Lionel.
339767
Reply By: Robnicko - Sunday, Dec 14, 2008 at 22:45
check the wheel bearings for play.
339771
Reply By: Member - joc45 (WA) - Sunday, Dec 14, 2008 at 22:53
Did you make sure the universal yokes went back the same way as they were dismantled when you replaced the uni crosses?
Gerry
339774
Follow Up By: Dune Climber - Monday, Dec 15, 2008 at 21:06
Yes, marked when dismantled.
607440
Reply By: Malleerv - Sunday, Dec 14, 2008 at 23:03
Replace front end bushes. All Bushes including track rod bushes. they may look ok but any degradation of the rubber will cause unwanted movement.
339775
Reply By: Member - Andrew (WA) - Sunday, Dec 14, 2008 at 23:08
Does it only happen in 5th gear??? not 4th at same speed?
If so, could be the gear box. Had the same symptoms in a previous Patrol myself if this is the case. I'll elaborate if this is your issue too.
339777
Follow Up By: Dune Climber - Tuesday, Dec 16, 2008 at 18:04
Hi Andrew, the vibration appears to be less in 4th, although is still there. I have always had the opinion that it is from "transmission/drivetrain" but have been unable to determine exactly. Had 5th gear replaced approx 3yrs ago(30000K's ago).
Still checking other suggestions but very interested in your gearbox suggestion.
DC.
607553
Reply By: Member - Duncs - Sunday, Dec 14, 2008 at 23:31
Does it go away when you are cornering, particularly in lefthanders?
If so check panhard rod bushes. My old GQ developed a problem that started out as you have described and got so bad that I could bearly hold the wheel.
It was panhard rod bushes. A general mechanic in
Nyngan picked it up after I had spent over two years visiting all kinds of
suspension specialists. They all wanted to fix the big things and it really was something quite small.
Duncs
339780
Follow Up By: Dune Climber - Tuesday, Dec 16, 2008 at 18:10
Duncs & Coyote, don't notice any variation when turning left or right.Once started vibration remains constant up to 100/105 kmh and then goes.
DC
607554
Follow Up By: Member - Duncs - Tuesday, Dec 16, 2008 at 23:22
The other thing it could be is disc rotors out of round or warped.
Mine was doing it at about the 120,000km mark when my mechanic recommended the discs be looked at because the pads were
well down and I had a bit of a "pump" effect under moderate braking.
I have no problems now but the wheel rotation issue does show up from time to time. Like others have said the Nissan
suspension seems quite susceptible to minor misalignment and balance issues.
Good luck with it. These issues can drive you nuts until you sought it out
Like I said before it could be something quite small. Try changing tyre pressures. At least that won't cost you anything.
Duncs
607632
Reply By: Member - Coyote (QLD) - Monday, Dec 15, 2008 at 11:06
I have a 06 GU 4.2 with the same problem.. seems to get worse in corners (eg gentle corner on a freeway at 85-90km/hr seems to start it up an then it seems to get better onthe straight but not completely dissapear. will watch this post with interest too.. (
also pulls to the left quite strongly) and I have had several wheel alignments and brand new tyres..
339815
Reply By: Member - Lynton B (QLD) - Monday, Dec 15, 2008 at 11:40
I had the identical problem as Coyote with my 2000 GU 4.2 diesel Patrol. Had
suspension, tyre specialists and one Nissan dealer look at it with nothing but short lived success. However since having the car regularly serviced by another local Nissan dealer I have not had the problem in over 50 000 km. I believe the problem was remedied through tyre rotation [especially front to back] every 5000 km and correct wheel balancing - which is Nissan's recommendation anyway. I found that unless this rotation is specifically requested the dealers, during the 5000/10000 km
services - generally put the better tyres on the front which are - up to a certain km - the front tyres themselves. I hope this helps.
339825
Follow Up By: Dune Climber - Tuesday, Dec 16, 2008 at 18:18
Lynton B, thanks for info. I agree with your comments re rotation at
services-have the same issue. Are you running original steel
wheels?
DC.
607555
Follow Up By: Member - Lynton B (QLD) - Tuesday, Dec 16, 2008 at 23:39
Yes DC am running on original steel rims. Do you suppose a problem exists there? Regards LB
607635
Follow Up By: Member - Coyote (QLD) - Wednesday, Dec 17, 2008 at 08:50
I have two sets of
wheels. Original 17" Alloys with original tyres on - wobble happens, now have brand new tyres on original rims.. wobble still happens, I also have a set of 17" steel rims with "Bush" tyres on.. wobble still happens.
I am 100% sure it is not my tyres or my rims or my wheel allignment or my wheel balance as all have been checked and rechecked etc..
607658
Reply By: spudnit - Monday, Dec 15, 2008 at 16:56
My 2000 model also was doing this. Did everything you done. Then had the shims in king pins done End of problem. The lift kit caused the wear. Anyway 2 hr job some 20000kms ago fixed problem
339862
Follow Up By: Dunaruna - Monday, Dec 15, 2008 at 18:58
They don't have kingpins, do you mean the swivel housing bearing preload shims? If so, I agree, too much freeplay can cause frontend woobles.
607411
Follow Up By: Dune Climber - Monday, Dec 15, 2008 at 20:55
Had the shims removed by Nissan service but made no difference.
607433
Follow Up By: ross - Wednesday, Dec 17, 2008 at 00:50
Engine and gearbox mounts gone soft or broken?
607642
Reply By: Member - Barney Rubble - Tuesday, Dec 16, 2008 at 20:53
Gday dune sorry for the late reply but always look at issues with 4.2 nissans
mate i had i similar issue after the lift kit and fatties went on but vibration was around 120k s and could not get the steering wheel straight with wheel alignments
as the lift had moved the rear diff to the left therefore the tailshaft was outa line and rear
wheels too
easy fix with adjustable panhard rod however patrols are mogrels to keep
wheels balanced
mine still has a mnor steering wheel shimmy around 90ks
hope this helps Cheers
Barn
340027
Follow Up By: Member - Barney Rubble - Tuesday, Dec 16, 2008 at 20:55
aaagh woops sorry moved Right Cheers
607598
Follow Up By: Member - Coyote (QLD) - Wednesday, Dec 17, 2008 at 08:54
I have been told that Patrols are set up for left hand drive roads (ie, roads cambered to the opposite side to us. I have been advised to get a kit installed that offsets the suspension/ alignment the other way. Not sure exactly but I think it was about $1200..
To my way of thinking, if this is the case then whay aren't all patrols doing this and then if so, why doesn't Nissan address it. I should not have to spend $1200 to get my car to drive in a straight line FFS...
607660
Reply By: Member - Charlie M (SA) - Wednesday, Dec 17, 2008 at 23:38
About that year early models of late shape had balance problems and
wheels had to be balanced on Nissan centre cone and wheel nuts done up in correct order to help fix problem, later patrols not so much problem with wheel nut order but still needs correct centre cone
Charlie
340197
