Satelite TV dish. How to transport?
Submitted: Monday, Dec 15, 2008 at 14:55
Warstar
I have been deterred from buying a
satellite TV system by the inconvenience of carrying the dish. As I understand it, users either store them under their (Queen size) bed, or on a roof rack.
Has any one tried some simple clamping device attaching it to the back, front or side (illegal probably as over width) of the van?
I cannot warrant the $$ for a roof mounted auto type, in any case I usually poke the van as far under a tree as possible, are there easy alternatives?
Reply By: Gone Bush (WA) - Monday, Dec 15, 2008 at 15:08
If you're not using a tripod there are a couple of ways.
Using a dolly wheel bracket bolted to the draw bar, just put the dish on a piece of straight aluminium pipe.
Alternatively, put the dolly wheel bracket on the rear bumper and bend a pipe into the appropriate shape and put the dish on that.
339850
Follow Up By: Warstar - Monday, Dec 15, 2008 at 15:46
Hi Gone Bush, Yes I will be using a tripod or probably a star picket with a bracket welded to it, but it the transporting between stops me.
I have seen your suggestion of the pole on the A frame used and I think that would be OK. The "Aussie" brand caravans come with Sat TV as standard and I think that is the system they use.
Thanks for your suggestion.
607389
Reply By: Gone Bush (WA) - Monday, Dec 15, 2008 at 16:01
OK, the other system I've seen to carry a tripod and dish was a large diameter poly stormwater pipe (sufficient diameter to slide the collapsed tripod into) vertically bracketed to the back of a van (or the front, wherever it fits best) with a cutout to lock the dish bracket into and a vinyl cover for the dish. It even included a padlock to ensure it's there when you want it.
It seemed a really good idea.
339853
Reply By: PeterInSa - Monday, Dec 15, 2008 at 17:06
Warstar,
I carry our 90cm oval Sat dish on the A Frame of our Van. The original Jockey wheel was mounted on a clamp about 60cm from the Van/tug coupling. I use this clamp and welded another clamp near the van/cruiser coupling. I purchased an approx 50mm tube 90cm long and used the original jockey wheel clamp to hold it. Put 1/4" bolts thru the tube so the pole could not slip down/up the clamp.
Approx 700, up the mounting pole (50mm tube) positioned anothe 1/4 bolt, with a brace to the front bolt of the Van coupling and another brace down the side to the A frame. This further prevents sideways and front/Back movement.
Used Ubolts to hold the Dish (backwards) onto the pole and a further 2x1/4" bolts thru the pole and the dish mounting frame to firm up the dish on the pole.
Also made a bracket to attach the bottom of the dish to the pole.
When travelling can line up the vehicle/van so all I need to do is undo 7 nuts turn the dish around lock onto the Sat then tigthen up the ubolts and watch TV.
Mounting pole should be at least 2mm thick if mounted on the A frame. Top of our dish is about 100mm over our cruiser. We can also open the front boot when the dish is positioned for travelling.
Have also made a fitting so that the Dish/mounting pole can be taken off the van and using 3 tent spreaders and steel pegs can be set up as a tripod.
339864
Reply By: Member - Mike - Tuesday, Dec 16, 2008 at 13:36
I thought the idea of hitting the road was to get away from things like TV - But then again I haven't got kids to worry about.
Cheers 4 now
Mike
339979
Reply By: Telsat Communication Aust Pty Ltd - Tuesday, Dec 16, 2008 at 16:29
we have new tripod specially desgined for caravan and motor home satellite system. For more details visit our website: www.telsat.com.au.If any 1 want to know about satellite system your are wellcome to ask .
regards,
almas
339990
