Nissan Navara auxillary wire
Submitted: Monday, Dec 15, 2008 at 22:02
Al-one
Hello everyone,
I wish to find a source of 12 volts on a Nissan Navara that is only powered up when the igntion switch is in the Accessory position or Ignition position. I don't want to remove too much (eg dashboard etc.) from the vehicle to find the wire.
Has anyone got any hints?
Al-one
Reply By: Member - Phil G (SA) - Monday, Dec 15, 2008 at 22:22
One of the wires to the wiper motor (check with multimeter) will be a fused source of 12V IGN power if you want to fit a battery isolator or energise a relay.
339936
Reply By: Grungle - Monday, Dec 15, 2008 at 22:38
How much current do you want / expect to use?
David
339941
