Warning Nissan Navarra and fancy wheels and Merry Xmas
Submitted: Tuesday, Dec 16, 2008 at 18:54
ThreadID: 64328 Views:3403 Replies:3 FollowUps:3
evening all
just a warning to all who may have a late model navarra with fancy wheels to check the wheel brace
daughter rang on sunday from just down the road had a flat tyre could i please come and help(unusual as she is normally capable of changing a wheel as i made sure all 3 kids could do it as part of thier driving instruction)
anyway jack (unused before)was extremely tight wound up to lock in had to get a solid rod to loosen to get it out from behind seat then go to loosen wheel nuts with nissan wheelbrace DOESNT FIT so try my cross wheel brace DOESNT FIT ended up using a socket and rachet with short extension the nuts are either bigger or the holes are smaller (my choice)
so if you own 1 of these check the fitting
MERRY CHRISTMAS TO ALL ON EO
steve and denny
Reply By: Member - Mark G (NSW) - Tuesday, Dec 16, 2008 at 19:23
STEVE
what model is it?
AnswerID: 340009
Follow Up By: Sir Kev & Darkie - Tuesday, Dec 16, 2008 at 19:29
Ken,
It is a Missan who cares??
Russell Coight:
FollowupID: 607568
Follow Up By: The Geriatric Gypsies - Tuesday, Dec 16, 2008 at 22:04
mr dark you will keep lo.,olol
mark 2008 model
steve
FollowupID: 607622
Reply By: Tippa - Tuesday, Dec 16, 2008 at 21:31
Thats unusual that different size wheel nuts are used on alloy wheels compared to std wheels... usually they may have a different shank length or seat shape- flat or tapered, but nut is usually the same size...
Great info mate as i'm sure most if not all would get caught by this trap, even the new car dealer too!
AnswerID: 340036
Follow Up By: The Geriatric Gypsies - Tuesday, Dec 16, 2008 at 22:09
goodday tippa
the nut is recessed and i believe the hole is not a big enough diameter to allow a normal wheel brace in and after looking at the nissan brace you could not turn it down as it was pretty thin already
dont believe the dealer would know and who ever suplied the tyres probably doesnt realise either
steve
FollowupID: 607624
Reply By: Member - Phil G (SA) - Wednesday, Dec 17, 2008 at 21:37
Sounds like aftermarket wheels??
I found the same with my daughter's pulsar (19mm on the ROH mags instead of 21mm on the factory ones), and the same with the Kimberley mags (ROH) on the Prados.
AnswerID: 340178
