Caravan Plumbing
Submitted: Tuesday, Dec 16, 2008 at 21:53
Member - Cookie & Di
The Brass thingo that is under my van between the external mains
water connection & the van piping is dripping. Even when the supply tap is nearly turned off .Could this mean its nearly knackered or what?
Reply By: The Geriatric Gypsies - Tuesday, Dec 16, 2008 at 22:00
its probably the pressure relief valve and they all seem to b/
well drip
steve
340040
Reply By: Notso - Wednesday, Dec 17, 2008 at 00:50
If it's a modern van it's probably a pressure reducer or a non return valve and it shouldn't drip.
I pulled a mates pressure reducer out a while back and cleaned it up, but it only worked for a short while and then they had to replace it anyhow.
340050
Reply By: Angler - Wednesday, Dec 17, 2008 at 22:13
I agree it is probably the pressure reducer and it should not leak.
Pooley
340183
