Can I somehow convert .JPG maps to .map files for Oziexplorer ?
Submitted: Wednesday, Dec 17, 2008 at 20:24
ThreadID: 64354 Views:14539 Replies:5 FollowUps:7
Sorry if it's a really dumb question.
I have always just used the map files from natmap etc, but I seem to remember people importing jpg files and converting them somehow. Am I having a lend of myself ?
There is a guy on eBay selling three CDs of gold maps of NSW and Vic. they are all jpg and not a lot of use if I cannot put them on Ozi to see where I am on them.
Thanks a lot,
Willie.
Reply By: equinox - Wednesday, Dec 17, 2008 at 20:27
Willie,
In Oziexplorer, Click file, then "Load and Calibrate Map Image".
Then it's a matter of calibrating the image and away you go...
AnswerID: 340162
Follow Up By: Member - Willie , Sydney. - Wednesday, Dec 17, 2008 at 21:44
I have been told that the maps appear to be hand drawn . I guess if they are not accurate, calibrating them is out of the question.
I think I will have to buy them to find out. Suck it and see !
Thanks,
Willie.
FollowupID: 607786
Follow Up By: equinox - Wednesday, Dec 17, 2008 at 21:47
Hand drawn maps are the best maps Willie :)
FollowupID: 607787
Follow Up By: Member - Willie , Sydney. - Wednesday, Dec 17, 2008 at 22:00
Do you mean like treasure maps with an "X" on them, or are you serious ?
Remember Alan, you are dealing with a techno idiot here.
Willie.
FollowupID: 607791
Follow Up By: equinox - Wednesday, Dec 17, 2008 at 22:06
haha..no, give me a treasure map any day!!!
FollowupID: 607792
Reply By: Von Helga - Wednesday, Dec 17, 2008 at 20:34
Willie,
Ozi works with two files one is the map in JPG or ECW format (plus others) and the dot map file (.map) which is the georeferencing for the map.
Ozi supports a lot of file formats and you can calibrate virtully any may you get or scan using the calibration option.
Check out the help file for details.
When you buy a HEMA dighital map CD for example you get both files and hence it works.
AnswerID: 340164
Reply By: Von Helga - Wednesday, Dec 17, 2008 at 20:37
sorry you don't convert from .JPG to .Map but georeference the .JPG file which gives you a .map file
AnswerID: 340167
Follow Up By: Member - Willie , Sydney. - Wednesday, Dec 17, 2008 at 21:42
Thank you for your help.
Willie.
FollowupID: 607785
Reply By: Member - joc45 (WA) - Wednesday, Dec 17, 2008 at 23:39
Hi Willie,
Whatever map formats you use, jpg, tiff, ecw, etc, you will need to have either accurate Long/Lat coordinates or UTM coords already marked on the map so you can calibrate the map in Ozi.
The tool "Load and Calibrate Map Image" under the File menu allows you to then calibrate against those coordinates. The resulting calibration produces a .map file. You must have at least 3 useable coordinates on the map to calibrate it, preferably more.
If the map has no coordinates marked on it, you can still calibrate the map if you have known GPS waypoints which you can accurately identify on the map; eg a town or other point on the map.
Hope this helps,
Gerry
AnswerID: 340198
Follow Up By: Member - Willie , Sydney. - Thursday, Dec 18, 2008 at 08:22
Thanks for the info Gerry. I will buy the maps and have a go . I might have to come back here for more info.
Willie.
PS Your second photo reminds me of Meeting Gorge.
FollowupID: 607811
Reply By: Ozboc - Thursday, Dec 18, 2008 at 15:59
I actually use the maps from google earth ( PRO) i just get the photo In high res - ( takes a few min for google earth to render to Jpg)
then import into oziexplorer - then calibrate. I find that 2 reference points is usually more than enough - the more you put in the far more accurate you need to be , and lets face it - when your just talking a few meters difference overall in a map - its not that important.
as for calibrating - i use things such as water towers street corners , track crossings as reference points.
as google earth maps are Above shots - you can find rivers and tracks easily
after all that - i then save to a separate folder Independent of my MAIN maps - so if i go into barring ton tops for example - i will use my usual shonkey maps to get me there - then will go to the folder where i have saved the overhead views and switch to that when i want to go looking for a new track or access to river or water ....
hope this has been some help ....
Boc
AnswerID: 340313
Follow Up By: Member - Willie , Sydney. - Saturday, Dec 20, 2008 at 12:03
Thanks Boc,
All helpful advice. I use Google a lot, to find things in the desert, so it makes sense to actually import the saved picture in as a moving map. I will try that.
I have just down loaded some free gold area maps from a Vic gov site. I will attempt to import and callibrate them into Ozi as well.
Willie.
FollowupID: 608272
