Landcruiser 1HDFTE Wiring Diagram
Submitted: Thursday, Dec 18, 2008 at 08:12
ThreadID: 64365 Views:25048 Replies:5 FollowUps:6
I was wondering if anyone might know where i might obtain a wiring diagram/s for a HDJ79R with a 1HDFTE in it. I'm happy to buy them if someone can tell me where? The wiring diagrams in the aftermarket manuals are not corrent for this model landcruiser.
The reason i am chasing them is i keep blowing my wiper fuse which seems to also supply the speedo and reversing lights???? When this fuse is blown the engine is cutting out when you coast to and intersection, is starts and idles perfectly straight way???
Reply By: MEMBER - Darian (SA) - Thursday, Dec 18, 2008 at 09:32
If the good oil doesn't bubble up here, you should join the relevant section at http://www.lcool.org .......... those members are just brimming with helpful, expert advice.
AnswerID: 340237
Reply By: Steve63 - Thursday, Dec 18, 2008 at 10:48
You can get them from Toyota as a multi part workshop manual. Each bit electrical etc is sold seperately so it is not a huge outlay. There are quite a few variations from year to year and by region. The workshop manuals have them all. They are not that expensive. I was highly surprised at the cost. Not like the ones for a Jack that were only sold as a full set for over $1,000.
Steve
AnswerID: 340250
Follow Up By: yowie - Thursday, Dec 18, 2008 at 13:31
thanks for the reply.
According to Toyota they don't have printed manuals i have heard there is a CD manual but they won't admit to that either. If you have one can you give me the part numbers?
FollowupID: 607882
Reply By: Oldsquizzy (Kununurra) - Thursday, Dec 18, 2008 at 19:28
http://forums.bauchan.org/portal/downloads.php
You could try here.
AnswerID: 340361
Follow Up By: yowie - Friday, Dec 19, 2008 at 06:38
Thanks for the link.
FollowupID: 608060
Reply By: Member - DOZER- Thursday, Dec 18, 2008 at 22:40
Phil, i have a factory 1hz/hdfte motor manual....would what you need be in there...explain exctly what you r looking for and i will check 4 u
Andrew
AnswerID: 340412
Follow Up By: Member - DOZER- Thursday, Dec 18, 2008 at 22:51
ok the manual is for a 100....if i am hearing you right, you want to know why a blown fuse for taillights is stalling the motor.... i know that the electronic throttle control system has a fail safe should the motor loose road speed and/or tacho reference, the VSV closes the throttle butterfly. With the accelerator at idle position, it will restart.
Andrew
FollowupID: 608024
Follow Up By: yowie - Friday, Dec 19, 2008 at 06:27
Thanks for the reply that sounds like what it might be. I was interested in what else might be connected to the wiper fuse ( so far: Wipers, Washers, Speedo, Reversing Lights ) as i still am not 100% on why it blew in the first place.
Also can i ask were did you buy your manuals from as i'm having no joy with Toyota.
FollowupID: 608059
Follow Up By: Member - DOZER- Friday, Dec 19, 2008 at 17:12
I kept an eye on ebay for it. javnt seen more than 2 in as many years....you could buy motor manuals for the early 100 t/d from Toyota. Dont know about now.
Andrew
FollowupID: 608152
Reply By: Member - JohnR (Vic) - Friday, Dec 19, 2008 at 07:12
there are some paper manuals on ebay and the link has a buy it now price. There is $10 or so postage but someone may know the quality, but lists the 79 and 100 Series.
AnswerID: 340437
Follow Up By: yowie - Friday, Dec 19, 2008 at 08:25
Thanks John i have one of these manual but the wiring diagram is for a 75 series not 79 series and they are very different.
FollowupID: 608077
