How to stop a sagging awning ..
Submitted: Sunday, Dec 21, 2008 at 16:07
ThreadID: 64459 Views:7063 Replies:10 FollowUps:5
Recently purchased a Pod Trailer Camper with awning ...
The awning wall has velcro to attach to the main tent and a zip along the top join .. because of the extra weight of the wall the awning sags in the middle ..
So how do I stop it ?
My thoughts were a piece of Aluminium strip with Velcro stuck on both sides ??
Anyone else got any equally brilliant ideas ?
Steve
Reply By: RobAck - Sunday, Dec 21, 2008 at 17:33
Go to polarisinnovations.com.au and have a look at their accessories page I think. They offer an extendable pole with a spring loaded X which works a treat. We have one of their rear awnings and it solves the flapping problem with that and we also use it for our Black Wolf when the awning is up as the do flog around in the wind
RobA
AnswerID: 340798
Follow Up By: Mandrake - Sunday, Dec 21, 2008 at 18:29
That site is for scooters for the disabled - not quite ready for that yet .. Couldn't see any camping accessories or poles ?
FollowupID: 608435
Follow Up By: RobAck - Monday, Dec 22, 2008 at 18:15
Try this than http://www.polarisinnovations.com/assoc.htm
Rob
FollowupID: 608563
Reply By: MrBitchi (QLD) - Sunday, Dec 21, 2008 at 18:56
Try www.polarisinnovations.com
Polaris
AnswerID: 340806
Reply By: MrBitchi (QLD) - Sunday, Dec 21, 2008 at 18:57
Polaris
AnswerID: 340807
Reply By: Mandrake - Sunday, Dec 21, 2008 at 19:12
Thanks for that - got the right site now ...
Not exactly what I am looking for buy might need one later
Steve
AnswerID: 340808
Reply By: Member - Phil G (SA) - Sunday, Dec 21, 2008 at 22:46
Not sure about your situation, but sagging awnings are easily propped up with an aluminium tent pole and a PET Coke Bottle over the top. The Coke bottle stops the canvas getting perforated by the pole.
AnswerID: 340832
Follow Up By: PradOz - Monday, Dec 22, 2008 at 08:50
or you can put a tennis ball on top of the pole - gets you out of playing tennis to leave more time for the beer :)
FollowupID: 608492
Reply By: Von Helga - Monday, Dec 22, 2008 at 11:28
Any chance of a photo of the problem??
AnswerID: 340865
Reply By: Mandrake - Monday, Dec 22, 2008 at 16:04
Image Could Not Be Found
Not the best photo - but you can see the great sag in the side wall .. Obviously it is too heavy for the awning roof to hold up - So I thought of sandwiching the alum strip in between the 2 velcro strips ??
Steve
AnswerID: 340898
Follow Up By: VicStar - Tuesday, Dec 23, 2008 at 15:35
Perhaps you need more guide ropes. A second one from the pole closest to us would help to redirection the pole. You seem to have two ropes on the pole to the far right, but I can't see it on the front pole.
Also, I wouldn't drape the tarp directly on to the tent - it just adds weight.
FollowupID: 608759
Reply By: Eucalypt - Monday, Dec 29, 2008 at 00:59
Hi Steve,
Looking at your photo you don't seem to have any poles coming from the tent to the top of the corner poles.They should run parallel to the ridge pole. Come to think of it you dont appear to have a ridge pole or gable poles. Take some time to make sure everything is square and certainly use double ropes on the corners.Does this make sence to you . Regards Terry
AnswerID: 341676
Follow Up By: Eucalypt - Monday, Dec 29, 2008 at 12:56
Steve,the awning should have a complete frame of its own.It should also have a pole that runs from the centre of the ridge pole to the centre of the horizontal pole on the long side of the gable.Send me an email to terrygg@iinet.net.au and I will send you the diagram of my awning. Regards Terry
FollowupID: 609370
Reply By: Mandrake - Monday, Dec 29, 2008 at 09:04
A bit more info --
The Tarp was thrown over fairly quickly when we were told a storm was coming ( and it did !! ) - My problem is the awning which is zipped to the camper tent - The side wall has a velcro strip which is attached to the awning roof and because it is heavy it makes the awning sag severely - I tried tightening the guys but all that did was undo the velcro - Should there be a ridge pole ? or as i suggested a piece of aluminium strip with velcro stuck to both sides just to keep the wall square ( not sagging down ) ...
Steve
AnswerID: 341688
Reply By: Steve - Monday, Dec 29, 2008 at 13:59
looks to me like all you need is a double guy rope on the nearest point in the photo. If you haven't seen them, they are just the same as the one you have only double and in the centre of the two, have a loop to go over the "pin" in the top of the pole and you peg them out at right-angles to one another.
AnswerID: 341715
