Cobbleston, use in Cobb
Submitted: Tuesday, Dec 23, 2008 at 12:48
ThreadID: 64512 Views:3237 Replies:4 FollowUps:4
Was talking to a guy at Cobb and he said the cobblestone are the equivalent of 12 heat beads and to be careful if using a whole one for a roast.
I use my Cobb for roasting and also as a base for a Beidouri oven which I use for stews .
Anyone had any experience with using the cobblestone and , if so , your comments on heat generated would be appreciated.
Pedro
Reply By: Supercalafreakinawesome- Tuesday, Dec 23, 2008 at 13:20
Hi Peter,
We've only used one yet (for about a 2 kg roast lamb) but yes we found them very hot. Definitely a lot hotter than beads. I will be only using 1/2 to 3/4 next time. I think they should be easy enough to cut.
Super
AnswerID: 341051
Follow Up By: Member - Peter R (QLD) - Tuesday, Dec 23, 2008 at 13:44
Thanks for that.
So looks like it would be too hot for the stew in the bedourie.
Pedro
FollowupID: 608737
Reply By: Member - Min (NSW) - Tuesday, Dec 23, 2008 at 17:05
Hi Peter,
We have used the Cobblestones a couple of times and think they are great - far better than Heat Beads. Each time it burnt for 2 1/2 hours and yes, they are hotter. In future I'd turn the meat sooner and/or use a rack (round cake cooler).
If you are organised and the roast is not too large you have enough time to cook a damper, scones or dessert after the meat and veges are finished.
We found Heat Beads (that's a brand name and the best of the lot) go off - probably absorb moisture. Cobblestones also take less space and you can halve them.
Thanks for the tip on the Bedourie, I'll try it.
AnswerID: 341097
Follow Up By: handy - Tuesday, Dec 23, 2008 at 17:53
i found with heatbeads after cooking a roast you should still have plenty of time to cook a damper etc as well. cheers
ps thats with the old style cobb.
FollowupID: 608790
Follow Up By: Geoff M (QLD) - Tuesday, Dec 23, 2008 at 20:13
As "handy" says, with heatbeads in the old style Cobb you have plenty of time for a roast and damper.
7 heat beads = 3 1/2 - 4 hours cooking time.
If you didn't loose so much heat out of the mesh in the new style ones you wouldn't need the cobblestones.
Geoff
FollowupID: 608818
Reply By: Member - Peter R (QLD) - Tuesday, Dec 23, 2008 at 20:15
Thanks for the further input.
As a matter of interest using the Bedourie in the Cobb I place it on top of a Trivett
Pedro
AnswerID: 341134
Reply By: Member - Duncan W (WA) - Tuesday, Dec 23, 2008 at 20:48
What are "cobblestone" heat beads & where do you get them?
I don't have a Cobb but use a Webber BBQ alot. Lately I've been finding the heat beads have been burning a bit cool and causing me headaches with the slow cooking times, so from what you're saying these Cobblestones would be just what I need.
Dunc
AnswerID: 341137
Follow Up By: Member - Peter R (QLD) - Tuesday, Dec 23, 2008 at 23:23
Check out this site
I bought mine at BFS.
Pedro
FollowupID: 608857
