Emergency welding with modified alternator
Submitted: Tuesday, Dec 23, 2008 at 20:11
pop2jocem
Hi all
Does anyone remember modified vehicle alternators to carry out said emergency repairs when out bush. I remember reading about them some time ago but I can't seem to find any info currently. Were they something that seemed like a good idea at the time but weren't all that practical at best or downrite dangerous at worst.
Anyone got any info please. Yes I know that some success has been had by hooking 2 or 3 batteries together but regulating the current always appears to be the challenge.
I would also like to take the opportunity to wish everyone a happy and safe Christmas and New Year
Cheers Pop
Reply By: Member - Ed. C. (QLD) - Tuesday, Dec 23, 2008 at 21:16
Did ya mean zis vun??
Unipower 185 | Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
341142
Follow Up By: pop2jocem - Tuesday, Dec 23, 2008 at 21:29
Ed. C. You've done it again. Dat B the wun
Thanks mate, and they are local (WA). I'll give them a call in the morning and get a price. Better make sure my pace maker batteries are in good shape. LOOKS EXPENSIVE. lol
Cheers Pop
608835
Reply By: Big Woody - Tuesday, Dec 23, 2008 at 21:25
Hi Pop,
Well this certainly brings back memories.
The welders you are thinking of are called AutoArc and were built by Goddards Auto Electrics in Western Australia many years ago.
We have had many of these in our family and I still think they were one of the best bits of gear you could fit to your car if you were travelling in remote areas. The first ones were quite primitive but as the years went by Goddards released the final models that were full of printed circuit boards etc.
I still have one in a box in the shed that I look at every now and then and wonder if it is worth going to the effort making it fit the 80 series. They have a 120amp alternator and a tiny pulley on the front to get it spinning fast to deliver the current. The alternator is very heavily wound.
I think the problem was as engine bays became more limited in space and replacing the existing alternator was not an option due to electronics and sensors etc, rhen the market for AutoArcs became limited to those with older vehicles.
When it came to welding with an AutoArc I dont know what it was but you couldnt do anything wrong. It was a very smooth weld and the rod would sing when you were running a weld. Penetration was great and was varied using the revs of the engine.
When throwing the AutoArc knifeblade switch the other way it would run the power to the 240 volt outlet. This worked
well but was 240v DC so was ok for motors and elements etc but I would not run anything with electronics off it.
My brother was a plumber and I was a carpenter both with F100's and I would often use the AutoArc for small jobs when working in the bush. From memory it would run a 1500 watt motor continuously and a 3000 watt motor intermittently. I had no problems running my 12cfm compressor even with the start up current. I normally had the car engine on about 1200 rpm but occassionally up to 1500rpm for a heavy welding job. No problems running power saws, drop saws, grinders etc.
I am preparing for a trip to the cape next winter and I think i will fit the AutoArc to the Landcruiser as I quite like having the ability to weld a trailer if need be on the side of the road. AutoArcs somehow also allow you to weld your own vehicle too. I think the battery is isolated from the alternator when the switch is thrown.
I hope some of this info is helpful and if there is anything else you would like to know give me a yell and hopefully I can help.
BW
341144
Follow Up By: Big Woody - Tuesday, Dec 23, 2008 at 21:31
Well after looking at Ed.C's post above it looks like they have not completely dropped off the radar as I has thought.
With a head office in WA I would assume that someone involved with the original AutoAcrs in the 1980's has further developed the product to keep up with changing demands.
The UniPower looks great. I am very interested.
608836
Follow Up By: pop2jocem - Tuesday, Dec 23, 2008 at 21:39
Big Woody
Thanks for the reply, I will give Goddards a call as
well We used to deal with these guys many moons ago when we had a crane repair business. I never realized they were involved with this stuff. Do you think the unit you have would fit under the bonnet of a HZJ75 Cruiser are the alternators any/much bigger than the standard one?
Cheers Pop
608839
Follow Up By: Big Woody - Tuesday, Dec 23, 2008 at 21:51
Hi Pop,
It was Goddards 20 years ago that were involved so I have no idea if they are still building them.
The alternators on my old ones looked identical to the standard ones that I was replacing in the f100's. I always thought replacing the diesel alternator was not an option as it is often also the vaccuum pump but I have discovered that this is not the case with my Landcruiser so that is why I am now considering fitting the unit.
If the HZJ75 is the same as the HZJ80 then I cannot see any issue with it fitting your cruiser as the physical size is the same as your standard alternator.
Let me know what you come up with in your research over there.
BW
608840
Follow Up By: pop2jocem - Tuesday, Dec 23, 2008 at 22:12
Woody
I think the engines are pretty much identical so if the alternator is the same size as the Auto Arc it should go straight in. I will keep you posted on the
Forum after some more digging. May be after Christmas though, pretty hard to get anyone interested in work at this time of year (including me) lol
All the best
Pop
608848
Reply By: Peter 2 - Tuesday, Dec 23, 2008 at 21:47
Here's the website
http://www.unipower.com.au/index2.asp
341148
Follow Up By: pop2jocem - Tuesday, Dec 23, 2008 at 22:02
Thanks for the reply Peter, I wonder if cost and more and more complex whiz bang gizmos (electronics ) spelled the end for gadgets such as these. I don't think you can get much more low tech than a HZJ75 Cruiser. I think the most sophisticated piece of electrics is the four speed heater fan lol. And one speed don't work anyway (note to self, must fix that one day)
Cheers Pop
608844
Reply By: Member - Mick O (VIC) - Tuesday, Dec 23, 2008 at 23:27
Pop,
I'm very keen on them as
well. Great looking set-up. Could you post the info to the
forum if you get a price from them as to how much the 185 unit costs.
Mick
341159
Follow Up By: pop2jocem - Tuesday, Dec 23, 2008 at 23:48
Yeah, will do Mick seeing as it was a story on your Blog that started my rusty mental machinery creaking over again about effecting running repairs of a welding nature in the bush. As I stated earlier I will try tomorrow however it might be after Christmas before I can get more info but I will follow up on this. By the way great stories, got my traveling need stirred up again.
Cheers Pop
608860
Reply By: Member - Jeff H (QLD) - Wednesday, Dec 24, 2008 at 00:53
A refreshing and interesting thread. We had a bloke break the yoke on a scraper some years back. Next thing a Tojo turned up, stitched the whole lot together, and off it went. I found it amazing that a (superficially) bleep -ant welder could do that. Must be expensive gear, yes?
(And no, I don't mean to imply that the scraper went back to work - it went to sick bay. /.....and we paid the medicals.)
I remain impressed by the performance of that unit, dead set.
Jeff H.
341165
Reply By: Peter 2 - Wednesday, Dec 24, 2008 at 08:31
I've been doing a bit of digging around on the net and it is possible to build your own version pretty cheaply.
Going this route though you need to be able to mount and drive a second modified alternator in the engine bay.
Unless you want to use it regularly I think I'll stick with batteries and the leads off the stick welder which hopefully you never have to use.
341172
Follow Up By: Member - Mick O (VIC) - Wednesday, Dec 24, 2008 at 09:49
G'day Peter,
I'd be interested to see what components you would reccomend. I did a post (60700) back when I got home with a view to investigating what options were available to build a variable ampage 12 volt unit. The only things I could come up with were a variable rheostat all of which cost more than $500. The other option was to buy a small CAD unit and a bigger inverter or carry a gennie, again both expensive options. With all the knowledge of
forum users, perhaps we could put our heads together and build something.
Cheers and merry Xmas, Mick
608870
Reply By: RV Powerstream P/L - Wednesday, Dec 24, 2008 at 19:42
Some years back I found a unit called Red Back which was an alternator set up that Telstra was using in cruisers and other 4 bys in the bush and they were made by a chap in
Alice Springs .
A firm in
Melbourne used to fit Telstra vehicles and had a surplus of them.
I bought one and made up a frame and fitted it to a 6.5HP Tecumseh vertical shaft .
It produced 240V DC , 120A of 12V Charge and 150A for welding.
The welding was a bit hairy but it glued things together and the 240 was regulated by revs.
A variable speed drill didnt like the 240DC and that cost a bit but the unit is still in the shed is superceded by an inverter welder.
The alternator had six winding and a bridge rectifyer.
Ian
341278
