OziExplorerCE Development Version 2.23d
Submitted: Wednesday, Dec 24, 2008 at 02:09
ThreadID: 64526 Views:3327 Replies:5 FollowUps:7
Hello
Some interesting inclusions in latest dev version such as 3D perspective....the update is just an exe file. Cut and paste into your existing ozice folder on gps and create new shortcut or change file name after deleting old exe.
OziCE dev version
Reply By: The Explorer - Wednesday, Dec 24, 2008 at 02:14
woops - christmas gremlin
OziCe dev Version take 2
AnswerID: 341168
Reply By: Peter 2 - Wednesday, Dec 24, 2008 at 08:33
Just installed it on my $200 nav GPS and it works a treat.
AnswerID: 341173
Reply By: Member - JohnR (Vic) - Wednesday, Dec 24, 2008 at 11:36
Greg, it runs well in my VMS, though I don't like the "course up" on maps much but the 3D doesn't look bad. It was different on a GPS where the roads turned around so you could read them. I had used the 2.22d version and hadn't found it unstable.
I would like a red or better night screen with it. Perhaps I should write to them about it.
The new 2.23d really gets connected quickly with a fast indexing and load. A lot faster.
Greg, thanks for the 'heads up'.
Have a good Christmas and hopefully a great 2009
AnswerID: 341196
Follow Up By: The Explorer - Wednesday, Dec 24, 2008 at 13:01
Hi John
I have had no issues with the latest few dev version either - seems very good. I use course up in the car on the 4.3 inch sceen, though as you say writing is upside down when you heading south. I don't use course up on the smaller screen gps I use in the bush as it gets confusing especially when using air photos/on foot.
All the best for the coming year
FollowupID: 608884
Follow Up By: The Explorer - Friday, Jan 02, 2009 at 10:40
John - your dreams have been answered as the latest dev version (2.24D) released yesterday has option for red night screen. Requires use of Screen designer to make a "button" to turn off and on (plus you must also use the original button for dimming backlight light as well (ie only operates when screen less than 100% bright)
Not sure how it looks when driving - havent been out.
FollowupID: 609898
Follow Up By: Member - JohnR (Vic) - Tuesday, Jan 06, 2009 at 18:11
Thanks Greg, I had been away but I see that 2.24d has been replaced by 2.25d. I have been playing with the Screen Designer but still have a little more playing to do I think. Trying to put buttons to the top right. I had exchanged emails with Des.
FollowupID: 610617
Follow Up By: The Explorer - Tuesday, Jan 06, 2009 at 18:22
Hello
I just modified existing page file and put red screen button in top right corner using screen designer - works. What issue were you having?
Have only tried red screen once last night - couldnt really see underlying map very well. Will try agian tonight.. maybe.
FollowupID: 610620
Follow Up By: Member - JohnR (Vic) - Tuesday, Jan 06, 2009 at 19:05
I was trying to adjust the wrong screen resolution. It is actually 480 x 234, not 480 x 272 that I had thought
Two buttons one to reduce the intensity, the other to change to red. Makes it easy and change the greying of two of the other buttons too to make them easier to see.
Ozi is heaps better than Memory Map once you have played with the two. MM is like Ozi Lite, light.
FollowupID: 610624
Follow Up By: Member - JohnR (Vic) - Tuesday, Jan 06, 2009 at 23:23
Greg, I have looked at some of my maps using the 'night' screen and find that some of the maps lend themselves to the colour more than others do. Red roadways aren't all bad but it depends on the background colour a bit. The Roof Top maps are pretty good. The button I have to drop backlighting intensity by 10% each touch is good.
FollowupID: 610699
Reply By: Member - Oldplodder (QLD) - Wednesday, Dec 24, 2008 at 12:48
Need to remember to get the new screen designer to go with it :o)
AnswerID: 341213
Follow Up By: The Explorer - Wednesday, Dec 24, 2008 at 12:56
...yes a few of the new features (eg use of elevation data) can not be used by way of the default screens, so you you need to create your own or modify existing ones. Havent bothered myself yet.
FollowupID: 608883
Reply By: The Explorer - Friday, Jan 02, 2009 at 10:44
New development version of OziCE and Ozi just released.
Ozi webpage
AnswerID: 342204
