Saturday, Dec 27, 2008 at 12:42
I was replying to those who said to use atf, I suggest that if you want to add this to your diesel for what ever reason, then dont use atf, but a 2 stroke oil that is designed to burn clean.
I agree that there is no point in doing it in later model stuff, just suggesting that 2 stroke is better than atf.
There are lots of stories of those adding old waste oil, petrol, atf etc.
Those out at my old work used to use Jeta1, and found that 2 stroke was far better for lubricity than atf, and left less residue on the injectors of thier work vehicles.
If I was in a position of having to use jeta1 for
fuel, then that is what I would use.
Re oil leaking into the induction side of the diesels from turbos, the problem here is that instead of metered amounts of
fuel being added, thus giving the required power, you dont have any control over the extra combustable material coming into the cyld.
So with fuel/ oil laden air charge entering the cyld, it combusts, and gives the run away that you mention.
re biocide,
ive no idea what oil companies do re adding stuff to their
fuel, and tanks, but have heard alot of stories where people have been caught before.
re alge lives grows, in the layer between
fuel, and
water.
so if you fill up at a
servo that has
water in their tanks, and they have alge in it, you add it to your
tank.
If you have any
water in it, it will grow, and block your system.
Making sure you dont have any
water in your
tank, is a good start.
Draining
tank drain, and also adding the additives I mentioned before like chemtec, diesel go, toyota additvive, nulon diesel additvie, have not only biocide to kill the alge, but also enables the
water to be mixed with the diesel, and burnt, leaving no
water in the
tank.
Keeping the
tank full, to reduce condensation helps too.
I personally used acetone in under 1% concentration when I first got my 2.8 lux after checking the
tank for any
water.
This ensured that any moisture in the
tank was removed.
I have also used acetone in petty as
well, and on the older carby cars, it works very
well, both in acting as a wetting agent for the
fuel, so you get better misting of the
fuel droplets, ie cuts the surface tension down, so they spray into a finer mist, which gives better smoother running.
It also cleans
well, both in petty, and diesel.
Just google for more info.
You can use metho in petty to remove the
water from the
tank, it enables the
water to mix with the petty, but if you use metho with diesel, it will seperate (esterfication??) the diesel into 2 different, distinctive layers of goodness knows what.
with my old ford, I added 1lt of metho to the
tank after winter to combat any moisture in the
tank.
I was a mechanic for a few years, and used the diesel go, nulon, chemtec, and toyota stuff all at different times.
Some customers put me onto these, they swore by it, as I was a diesel go man, so I investigated it further over time, both on thier cars, and those who had
fuel problems due to poor
fuel handling, or poor supplied
fuel where they got it from.
They all did what they claimed to do.
Having run all of the affore mentioned additives in my lux, I am happy with either chemtec, toyota, nulon, bp diesel go, and acetone, as they all give a bit more power, ie bugger all, but its there, reduce engine noise, and better milage.
I have shared my findings with mates, who have also been happy with the results.
But there is no substitute for good maintainence, its not a miracle cure all.
I hope that answers your questions.
not trying to teach you to suck eggs here, just wanted to try and be as clear as I could.
Trains
609141
