100 series electrical problem
Submitted: Saturday, Dec 27, 2008 at 23:54
ThreadID: 64599 Views:2244 Replies:3 FollowUps:0
Hi All,
While installing a 2-way in my 2004 std 100 series, I shorted the an auxiliary battery wire on the body. Now the tacho, voltmeter, temp gauge and glow plug light do not work, I have looked through all 3 fuse boxes and there are no blown fuses, any ideas?
Mark
Reply By: Member - Tony B (QLD) - Sunday, Dec 28, 2008 at 08:32
Mark. Did the same sort of thing on my Rodeo - yes you are not the only one who should have disconnected the battery before doing electrical work! I accidently shorted a wire in the fuse box I was connecting a lead too. I had a whole lot of funny things happening on the dash after that, warning lights on - that should not etc. Eventually I said to myself - Self would this be like your computer and when all else fails - reboot it. So I disconnected the battery so the car had no power and then reconnected it - my problem was solved that easy!
Maybee you could give that a go, may be a computor thing - but I would be more sure that you would have a blown fuse - sometimes they are not easy to see. Best of luck. Makes you wonder what you would do if you have an electrical fault out bush?????????? Cheers Tony
AnswerID: 341557
Reply By: Marklar - Sunday, Dec 28, 2008 at 09:53
Thanks Tony,
I'll give that a go. When I saw the sparks I thought to myself, maybe I should have disconnected the battery first! All seems to run fine, and it was the day before we headed off camping!
Mark
AnswerID: 341562
Reply By: Graham & Lynne - Sunday, Dec 28, 2008 at 11:14
Marklar
the "meter " fuse should be the only one that controls these things ,should be in RH kick panel.
from Graham
AnswerID: 341572
