DC Fridge Checklist
Submitted: Monday, Dec 29, 2008 at 13:36
ThreadID: 64628 Views:3483 Replies:5 FollowUps:3
Rewire the accessory plugs in your car with thicker guage wire
Rewire the accessory plug to the unit with thicker guage wire
Buy two 60amp solar panels
Buy a quality solar panel regulator
Buy three 100 amp hours battery's
Buy a quality automatic battery charger
Buy a quality generator
Buy 15 amp quality power leads
Buy some Jerry cans
Buy some jerry can holders
Buy a quality solenoid
Buy quality battery leads
Have all of the above professionally fitted
Buy several quality computer fans
Buy a quality controller, switch-gear, wiring, brackets, indicator lights and remote switchs for the fans. The fan controller is important. A cheap one will burn the dearer gear out.
Have these all fitted
Buy the fridge
Buy the digital temperature guage
Buy the fridges 240/12v rectifier with power-sensing - woops, cant get
Buy the 240/12v rectifier without power sensing - woops, cant get
Buy the fridges 240/24v rectifier with power-sensing - woops, your not 24v
Buy the 240/12v rectifier for thermoelectric fridge for the CF18
Buy a quality inverter to run everything on 240 volts
Buy quality leads
Have all these things fitted
Buy insurances for them all
Buy as computer and internet connection to keep up
Replace 10% of the above evey few months to maintain the condition of everything else
have i missed anything?????????
Reply By: Member - Mick O (VIC) - Monday, Dec 29, 2008 at 14:06
Refreshing beverages to put in the fridge and a couple of valium (helps you feel better about the money you've just spent)! Time to get outside for a stroll I think :-).
Cheers Mick
AnswerID: 341716
Reply By: HeatherG - Monday, Dec 29, 2008 at 14:08
yes
your last few entries on the checklist should be as follows
Remove the DC fridge
Fit a 3 - way fridge to your vehicle ( which can be powered by gas and you may never need to use the generator)
This is what we did after a 3 month trip north during the winter.
It has solved all our power problems!
We live and learn
AnswerID: 341717
Follow Up By: Max - Sydney - Tuesday, Dec 30, 2008 at 16:46
Heather - I assume Bruce was being funny, taking off the techos who love to make it complex.
Our three way lasted 13 years and travelled hundreds of thousands of kms, and all I did was make sure the power was turned off to it when the car was stopped so it did not flatten the battery.
About five years ago, we did get a compressor type fridge, but by then had put an auxiliary battery in the car. We now caravan with a three way in the van and the compressor type does freezer duty in the back of the car.
Never all that other hardware, but a tonne of fonne!
Max
FollowupID: 609548
Reply By: Hairy (NT) - Monday, Dec 29, 2008 at 14:12
"have i missed anything?????????"
Mmmm........you havent told us what drugs your on????
LOL
AnswerID: 341718
Reply By: Member - Mike DID - Monday, Dec 29, 2008 at 16:50
. . . . . hmmmm, the English have survived drinking warm beer.
I think I'll be able to get used to the taste of it !
AnswerID: 341738
Follow Up By: Maîneÿ (wa) - Tuesday, Dec 30, 2008 at 21:30
Mike, you won't need to get used to warm beverages
You have a decent fridge & 12v power system !!
Mainey . . .
FollowupID: 609578
Reply By: Member - Phil G (SA) - Tuesday, Dec 30, 2008 at 09:59
You need a digital multimeter To measure volts and diagnose problems.
AnswerID: 341838
Follow Up By: Max - Sydney - Tuesday, Dec 30, 2008 at 16:48
How about getting a certificate 3 in electrical wiring to check that its all been done right!
Should only take a couple of years!
LOL
Max
FollowupID: 609549
