exide extreme N70EXL
Hi All
K-mart have 25% sale on Car batteries bought exide extreme N70EXL today $155 as a second battery...
these batteries any good?
cheers steve
Reply By: Michael ( Moss Vale NSW) - Tuesday, Dec 30, 2008 at 20:47
Steve, I have 2 in my Patrol, only maybe 1 yo, going ok with a very thirsty fridge.. I bought one when the vehicle was new, hooked it up in parallel with the original battery as a second battery, lasted from July 03 to say beginning of this year so they last well. They are designed for heavy offroad use.. Michael
AnswerID: 341892
Reply By: troopyman - Tuesday, Dec 30, 2008 at 20:50
they dont fall apart on corrugations etc .
AnswerID: 341894
Reply By: Member - Phil G (SA) - Tuesday, Dec 30, 2008 at 20:53
I also have a pair of them under the bonnet - no issues - they are only 2 years old though.
AnswerID: 341895
Reply By: Maîneÿ (wa) - Tuesday, Dec 30, 2008 at 21:22
Steve,
You say: " bought exide extreme N70EXL as a second battery... are these batteries any good? "
Yes, they are excellent Cranking batteries with a 12 month warranty as such
Mainey . . .
AnswerID: 341897
Follow Up By: Member - Phil G (SA) - Tuesday, Dec 30, 2008 at 21:35
24 month replacement warranty.
FollowupID: 609579
Follow Up By: Maîneÿ (wa) - Tuesday, Dec 30, 2008 at 21:46
Phil, yes your correct, however the Extreme will revert to 6 months when used as a deep cycle only, the warranty expressed on the battery is for starting purposes both commercially (18 months) and private (24 months) The hybrid design that allows for cycle duty is within the function of the vehicle electrics, many large transporters have multiple electric devices that draw battery power with the vehicle running and this is the intended purpose of the hybrid design.
Whereas a deep cycle design caters for supplying power with no alternator running into it.
It will supply power for a designated time depending on the amp draw rate.
Any battery used out of application could have the warranty voided, the Extreme does have the potential for light cycle duty and is naturally a robust starting battery.
Mainey . . .
FollowupID: 609581
Follow Up By: Member No 1- Wednesday, Dec 31, 2008 at 07:40
i found that i was getting around 12months form those batteries when used as a deep cycle...till BIL (auto sparky) spoke to excide who then told him they aint a true deep cycle...and replaced it with one that was...went thru three all up
FollowupID: 609605
Follow Up By: troopyman - Wednesday, Dec 31, 2008 at 11:13
Exide extremes are not for deep cycle . They are great for winching though . I have 2 hooked up in parallel .
FollowupID: 609624
Follow Up By: Member - Phil G (SA) - Wednesday, Dec 31, 2008 at 13:59
Gday Mainey, I'm surprised that you can use an Extreme for deep cycle use and still get a 6 month warranty. Did this come from Exide?
I've used cranking batteries as my second batteries for the past 20 years. Its because I only ever lightly cycle them. In my case, running the Engel overnight in the desert only sees the volts drop to 12.5-12.6 in the morning. We use our vehicles every day, so the cranking batteries recharge fairly quick. All depends on what you do and how you camp.
If staying put, I use a 3rd battery - an AGM in the canopy, so I can stay put for a few days or run the second fridge.
FollowupID: 609652
Follow Up By: Maîneÿ (wa) - Wednesday, Dec 31, 2008 at 17:16
Phil,
Yes, you can quote me on "the Extreme will revert to 6 months when used as a deep cycle only, the warranty expressed on the battery is for starting purposes both commercially (18 months) and private (24 months)" as it was sent direct to me from Exide !
As you say almost any cranking battery can be used as a fridge battery "overnight" when the vehicle is used every day, however when not used in that situation nothing can match the performance of an AGM Deep Cycle battery for long term camping
Mainey . . .
FollowupID: 609677
Follow Up By: RV Powerstream P/L - Thursday, Jan 01, 2009 at 15:28
Mainey
"Nothing can match "an AGM is an overstatement .
Most AGM batteries are restricted to around 400 cycles to 80%DOD whereas some gels can give 1200Cycles to 100% DOD.
I agree that high recombination AGM's are good but I cannot accept the above statement unless it is expressed as "your opinion" which you are entitled to do but they are definatley not the best overall cycling battery.
Ian
FollowupID: 609782
Follow Up By: Maîneÿ (wa) - Thursday, Jan 01, 2009 at 19:48
Ian,
Aren't Gel cell batteries available in AGM construction :))
Mainey . . .
FollowupID: 609816
Follow Up By: Member - Mike DID - Thursday, Jan 01, 2009 at 20:08
There are three ways of holding the electrolyte in Lead-Acid batteries -
- Wetcell
- Gel
- AGM
FollowupID: 609818
Follow Up By: Maîneÿ (wa) - Thursday, Jan 01, 2009 at 20:14
Mike,
Gel AGM's :))
Mainey . . .
FollowupID: 609819
Follow Up By: RV Powerstream P/L - Friday, Jan 02, 2009 at 18:03
maney
If AGM and Gels are the same why was a major battery seller screwed for using the wrong terminology of some batteries they were selling calling them Gel when they were AGM with a smmear of gel near the top and low recombination at that.
AGM as you know is absorbed glass mat and even the high recombination ones still only have limited cycling ability compared to a genuine gel.
The biggest problem I have with the Top Gel available is that they are built to 2V 4V and 6V specs only and are considered that it is not economical to produce a 12V as the market here is too small so we are stuck with a cost comparative of using more batteries to get 12V.
However I would back the Aussie Built Gel in to belt any AGM in cycling ability and lifespan and and all capacities can be achieved in series charging not parallel charging which is the most efficient charging sysyetm.
ie 200AH 310AH 450AH 650AHin 12Volt and in ABYC and US Coast Guard approved Battery Boxes.
FollowupID: 609956
Reply By: Member - Kiwi Kia - Wednesday, Dec 31, 2008 at 06:55
Sounds like a good deal. I use them because if I have a problem there is usually another K-Mart (or dealer) that will honour the warranty not far away.
My previous brand of battery had a warranty that was only any good at a few places in the state where it was purchased (SA). That was no use to me when the battery karked out near Alice Springs after only a few months use.
AnswerID: 341920
Reply By: Member - Footloose - Wednesday, Dec 31, 2008 at 07:03
I have found them to be an excellent cranking battery with a decent warrenty if needed.
AnswerID: 341921
Reply By: Gone Bush (WA) - Wednesday, Dec 31, 2008 at 11:17
Sounds like an Exide at sale price and the BCF battery box mentioned in another thread might be a good combo.
Might be time to go shopping.
AnswerID: 341933
Follow Up By: Maîneÿ (wa) - Wednesday, Dec 31, 2008 at 17:22
Only if you want to save money.....
why would you want to put a Cranking battery in a dedicated battery box set up specifically for running accessories ??
I would want the most reliable CYCLING battery available in mine
(if I also needed all the accessories with the box)
Mainey . . .
FollowupID: 609678
Follow Up By: Gone Bush (WA) - Thursday, Jan 01, 2009 at 16:08
Always appreciate your comments Mainey.
Always informative but I did say AN Exide, leaving the choice of type from their range up to me.
FollowupID: 609787
Follow Up By: Maîneÿ (wa) - Thursday, Jan 01, 2009 at 20:00
True,
however, the post is about the Exide Extreme N70EXL
The only Exide battery mentioned is the N70EXL so yes I thought you would be buying that and not one of their other Cranking batteries to fit into the BCF battery box, unless of course you will buy one of the Exide Deep Cycle batteries ?
Mainey . . .
FollowupID: 609817
Follow Up By: RV Powerstream P/L - Friday, Jan 02, 2009 at 18:11
mainey
Price dictates the sale and quality is a secondary consideration but if it works for the buyer and the buyer is happy then what elsecan be said .
Even Charles Sterling of Sterling Power Products has an adversity to AGM and Gel Batteries and claims you can do just as good using cheap batteries with his smart gear and he maybe right but I hate people wasting money on batteries that only sell more batteries due to premature failure in the wrong application.
Ian
FollowupID: 609958
Follow Up By: Maîneÿ (wa) - Friday, Jan 02, 2009 at 19:45
ian,
what "Cheap battery" & "Sterling Power Products smart gear" do you recommend that can compare with a quality AGM battery system under the same applications & conditions ??
Mainey . . .
FollowupID: 610001
Reply By: RV Powerstream P/L - Saturday, Jan 03, 2009 at 11:08
Mainey
I dont recommend any cheap battery but Sterling claims with smart charging you can get better life and more capacity from any battery.
I specifically like Gel and AGM but only high recombination ones that can take a high charge and limit run time for charging that costs money and eventually is cheaper overallthan using cheap batteries.
The casual camper would probably get away with cheap batteries but anyone that does a lot of camping should look to long life and greater capacity and the high recombination Gel and AGM means that high capacity smart charging cannot be matched especially if its coming from the fuel that drives your vehicle that you are paying for anyway.
Recently we installed a DC DC 2412 30 unit on a 4x4 Hino with a fifth wheeler attached and on idle the unit was putting in more 12V power than the 4x 64W solar and or a 240V 30A smart charger fitted to the trailer.
Ian
AnswerID: 342399
Follow Up By: Maîneÿ (wa) - Saturday, Jan 03, 2009 at 16:15
Ian,
Yes, I agree, with the addition of any "smart charger" you will get better battery performance with BOTH the good battery and also the elcheapo battery.
I believe :) even with same 'assistance' to BOTH batteries the better performance is still available from the more technically advanced battery !!
Remembering the Unisolar panels would have been going into a regulator and would be registering only what the battery "needed" not what could be delivered by the DC-DC 2412 unit, so I believe :) it's an unfair 'comparison' to a degree, a bit like having a 100 Amp Alternator and thinking it supply's 100 Amps into the battery, but I understand what you are suggesting.
As an example only, shown here my 200 Watt Solar system is producing 12 Amps, the 14.2 Volt battery is receiving only 5 (of those) Amps.
Image Could Not Be FoundMainey . . .
FollowupID: 610128
Follow Up By: RV Powerstream P/L - Sunday, Jan 04, 2009 at 12:15
Then you should use an MPPT controller and get the wasted watts that goes out of the panel in heat converted to useable battery input .
I think a combination of smart charging using the fuel you pay for anyway combined with solar is the ultimate as with reasonable travel you may always when you stop have full batteries and then the solar guarantees the batteries last longer before alternate charging is needed .
It is good to be able to have enough solar but that is mostly not practical due to the footprint needed.
Ian
FollowupID: 610229
Follow Up By: Maîneÿ (wa) - Sunday, Jan 04, 2009 at 13:31
Ian,
you say: "get the wasted watts that goes out of the panel in heat converted to useable battery input"
When the battery is showing as 14.2v and simultaneously only 5 amps out of the available 12 Amps is being used to charge it, may I suggest it requires no more "watts" as it already has more that it requires !
My >200 Watt Solar 'footprint' is less than the roof size so it stays there 24/7 as I have nowhere to store it :)
Mainey . . .
FollowupID: 610235
