tyre pressure when towing
Submitted: Tuesday, Dec 30, 2008 at 21:15
ThreadID: 64655 Views:3020 Replies:5 FollowUps:0
does 36 front 39 rear sound about right when towing a 2 ton van?
have coopers st's fitted.
thanks
Reply By: Notso - Tuesday, Dec 30, 2008 at 22:25
I find following the car manufacturers recommendations works for me.
But if you have non standard tyres, eg Light Truck tyres. Then ask your dealer.
AnswerID: 341906
Reply By: ross - Wednesday, Dec 31, 2008 at 06:38
Whatever feels right. There is no hard and fast rule on tyre pressure.
Experiment with a few pounds each way and see how it feels.
Its the weight of the towing vehicle that is really important.
The caravan should only have about 10% of its weight on the towball.
AnswerID: 341918
Reply By: Member - Graham H (QLD) - Wednesday, Dec 31, 2008 at 10:13
Depends what you are driving as well.
EG A Patrol runs higher pressures standard than a Cruiser.
The 4lb rule is a good one.
That is hook up, take tyre pressures, drive for 15mins and take them again. To be correct they should be 4lb higher. More than that they are too low, less than that too high. also the same on the van.
Check on the "articles" above it has advice on things like that
AnswerID: 341928
Reply By: Member - JohnR (Vic) - Wednesday, Dec 31, 2008 at 10:49
Gary n Kerry, for the black you should be about right all things being equal. On dirt, stone and sand I would be dropping 10 psi, corrugations even lower. On loose sand another 10 psi lower.
Traction is boosted for all surfaces with the lower pressures, steep hills included. Your question is pretty open ended.
AnswerID: 341932
Reply By: Warstar - Thursday, Jan 01, 2009 at 12:06
I run my LC100TD at 48PSI all round when towing my 2300kg van on sealed roads. Works well. Have the tyres on the tandem axle van the same. Nothing gets too hot!
Most Tyre manufacturers will advise running tyres much higher than the vehicle manufacturers recommendation
AnswerID: 342076
