battery charging hundred series-hope someone can help
Submitted: Tuesday, Dec 30, 2008 at 21:52
ThreadID: 64657 Views:2239 Replies:5 FollowUps:2
i have a hundred series with two batteries which are isolated via a manual switch. the starting battery also has an isolating switch off the negative terminal. if the isolating switch from the starting battery is turned on will the charge then be directed to the deep cycle battery whilst the car is running? hope someone can help!!
Reply By: Member - Phil G (SA) - Tuesday, Dec 30, 2008 at 22:00
What model/engine is your 100series?
AnswerID: 341900
Reply By: tony.f - Tuesday, Dec 30, 2008 at 22:07
1998 diesel standard
AnswerID: 341901
Follow Up By: Member - Phil G (SA) - Wednesday, Dec 31, 2008 at 11:29
If you call it a 105series diesel, you'll get better answers.
FollowupID: 609626
Reply By: Geoff (Newcastle, NSW) - Tuesday, Dec 30, 2008 at 22:18
"if the isolating switch from the starting battery is turned on will the charge then be directed to the deep cycle battery whilst the car is running?"
Short answer is yes they will charge in parallel, equally if the switch is left in the on position both batteries will discharge in parallel.
(If I've understood your description correctly)
"the starting battery also has an isolating switch off the negative terminal."
Don't ever start the engine then turn both isolators to the off positions as you'll almost certainly fry the alternator. They require the battery as a load to regulate the voltage.
Would I be safe in assuming you bought the vehicle with this setup already installed?
Geoff
Geoff,
AnswerID: 341905
Reply By: Member - Phil G (SA) - Wednesday, Dec 31, 2008 at 11:38
Its a very cheap way to isolate batteries, but works fine if you understand the limitations.
Ideally your batteries should be identical in type, size, age and brand, because most of the time (including when you're stopped) they will be connected.
I don't know why there are 2 switches. The switch on the neg terminal of the starting battery sounds useless, so I'd remove it.
AnswerID: 341940
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 31, 2008 at 13:12
Hi Phil,
The only potential use I can see for the switch in the main battery negative is to take the main battery out of circuit when the auxilliary is in circuit thus directing all of the charge to the auxilliary.
What I can see here as yourself, Mike and I have pointed out is a whole heap of electrical grief courtesy of Mr Murphy.
Geoff
Geoff,
FollowupID: 609643
Reply By: Member - Mike DID - Wednesday, Dec 31, 2008 at 12:16
If through some fault neither battery is connected to the Alternator, it will produce a massive voltage surge that can destroy the Alternator and the loads.
Once the main battery is charged (and left connected), the Deep cycle will charge exactly as fast as if the Main battery were disconnected - just no danger of catastrophe.
Alternators CANNOT sense the state of charge of any connected battery.
I would remove the Isolating Switch in the Main Batt negative - no advantages - just high risk. If you want to ensure that it doesn't accidentally discharge, put the switch between battery and loads (ensuring the Alternator is always connected to the Main battery)
AnswerID: 341948
