Battery and charging
Submitted: Saturday, Jan 03, 2009 at 20:58
Bunny
We have ust had to replace firstly our caravan battery charger, and now some weeks later the battery.
What is the general consensus about charging a new battery. I have heard that we should plug into 240 volt every month and charge for a day or so.
Your expert knowledge would be appreciated.
Reply By: ABR - SIDEWINDER - Saturday, Jan 03, 2009 at 21:39
I would recommend a maintenance charger to be left on the battery. The once a month charge can still allow some build up of sulphation.
Derek from ABR
342485
Reply By: Maîneÿ (wa) - Saturday, Jan 03, 2009 at 21:39
Connect it to a (good) 3 stage charger when not in use and you will not have to do anything else
Mainey . . .
342486
Reply By: PeterInSa - Saturday, Jan 03, 2009 at 22:46
I would install a load cutout box. so if the voltage goes below say 10.5 volts the load is dropped off. But you don't go into the van you say, but only to get a bottle of sauce when you run out in the kitchen etc. Lights on an off over a period of time can lower the battery voltage.
Agree with above on using a maintenance charger, but would get a unit that blasts out 14.4 volts or so every so often to remove the sulphate buildup. One that does it automatically.
My unit I have to switch it over to do this, can only do it twice a month and have to monitor the SG of the battery over a three hour period.... All to hard.
342497
Reply By: RV Powerstream P/L - Sunday, Jan 04, 2009 at 11:56
Someone should have asked what is the charger that you have just replaced as if it is a good charge and maintain unit then why would you want to buy anything just plug it in and let it do its job as Mainey stated nothing else needed.
Ian
342552
