Saturday, Jan 03, 2009 at 22:52
Hi Mrbrush,
You would have an RFI made CD931 6.5db ground independent elevated feed antenna and your mate a GME AE4705 4.5 db ground independent antenna. The RFI antennas are probably the best in Australia with the GME coming in around third or
forth.
I also have the GME AE4705 antenna and believe they are pretty good. I have tried many different types with some being better than my current selection but I settled on that particular model for a couple of reasons.
1. They are super strong and can handle decent bird strikes.
2. They can be quickly removed (except for the spring).
3. You can take off the 4.5db antenna and add either the AE409L whip in 6db or 9db form for longer distance communications.
4. 4.5 db is a good compromise between hilly and flat terrain.
No-one can accurately calculate max distance from an antenna as so many factors dictate the transmission pattern of an antenna. Decent manufacturers will have a radiation pattern plotted that is based on an EIRP (Effective Isotropic Radiated Power) but this is usually based on their antenna being mounted in the centre of a roof of a vehicle so is not really practical in real life.
Gain of antenna, mounted height / position, how vertical antenna is, quality of coax (attenuation), quality of connector and fitting, output power of radio, obstacles in path of transmitted signal - even time of day can all affect the transmitted signal.
I can say that the CD931 is a top antenna which should see a good transmission pattern radiated. It uses quality double shielded coax (Cellfoil) and connectors are pre-crimped with adaptors supplied for different radio types. Unless you cut the pre-terminated connector off and put your own on, then I would say that the problem you describe above could be with that. Otherwise you could have had something rub through the coax to create some RF attenuation or your radio is down on power.
Popping into a radio communications
shop and asking for a VSWR test will reveal the health of you setup.
To put a rough guesstimate to your original question re distance then I would say around 4km in hilly areas, 8km in moderately flat areas with some small hills to 12km in flat country. However anything is possible and transmission distances of 20-30km are not unheard of if conditions are right (being on top of a
hill for instance).
BTW we sell radios and antennas.
David
342498
Follow Up By: Mrbrush - Sunday, Jan 04, 2009 at 00:05
That sounds like the problem as I can pick him up further with the 6.5db and he just can`t quite pick me up using a 4.5db.
It certainly makes sense.
Thanks grungle
610192
