12h-t service
Submitted: Monday, Jan 05, 2009 at 13:32
ThreadID: 64829 Views:4075 Replies:5 FollowUps:4
Hello all, hope we're all having a good new year.
Just after some info on oil, fuel filters and also coolant.
I had a mate give me some filters and oil he works with cat, the filters are all fleet guard and what i can find some people are using these part numbers on there 12h-t but i would like to confirm that they are as good as toyota original oil/lube filter # LF3399, fuel filter # FF5114.
The oil is valvoline Extra LD 15w-40 #1109.20 valvoline have informed me that this oil is of a higher grade and oil changes can be increased. Should i still do the 5k change.
Also the car has a smoke(black) Just a puff every time i start her up, was looking at maybe doing an engine clean with a CME?? product or similar what do you guys recommend?
Finally coolant What should i use.
Also got the filters lube for $12 and fuel $7 if these are ok filters dose any body know where to get them in melbourne for this price mate lives in FNQ so a bite of a hike.
Cheers & cold beers..........Steve.
Reply By: Dave B (NSW) - Monday, Jan 05, 2009 at 17:26
Steve, my 12HT blows just a faint whiff of black smoke on startup and I haven't lost a wink of sleep over it. Mines only done 230K though.
The fleetguard filters are very good IMHO, and are used throughout the trucking industry, so I don't think there would be any problems.
The 5K oil changes, I still do the 5K oil change even though the specs for changing the oil was done about 25 years ago when that motor came out, and the oils were not quite as advanced. I assume they took into account the quality of the lubricant at that time and 25 years on the quality of the oil is much higher to cope with the new engines.
The thing that I think about is that the design of the 12HT is not necessarily as clean burning as the new engines, so probably contaminates the oil enough to warrant more frequent oil changes.
I will happily stand corrected if I am barking up the wrong tree there.
I would love to extend my oil changes, I hate giving the oil companies more money, they get enough out of me now.
Coolant, I use Tectalloy Gold.
Dave
'Wouldn't be dead for quids'
AnswerID: 342754
Reply By: Davo_60 - Monday, Jan 05, 2009 at 17:32
G'Day Steve,
Don't know much about the fleetguard filters, I use toyota filters on my 60 (2h). You should still do the oil changes at 5k regardless of the oil quality as it will still become contaminated unless you improve the filtration system. I know people who have used flushes such as CEM with good results, however probably won't fix the black smoke at start up. A puff at start up is not a problem (fairly normal), but if black smoke is generally an issue then look at injectors, timing and fuelling.
AnswerID: 342756
Reply By: Oldsquizzy (Kununurra) - Monday, Jan 05, 2009 at 20:00
450.000 klms and still going strong..Service every 5000 klms if auto drop and change every 25000 klms.. Injectors at each 200.000 klms and fuel pump and turbo rebuild at 350.000 klms. I do my valve adjustment every 25000 klms as well. They have a habit of wearing out rockers. Touch wood hasnt happened yet to me. And I get the puff at start up as well dont lose sleep over it they all do it.
AnswerID: 342771
Reply By: PeterInSa - Monday, Jan 05, 2009 at 22:54
Steve,
I understand that the puff of black smoke is due to the Direct Injection setup of the 12HT. Like the above, it does not bother me, except when the wife is in the vehicle and I start up to close to her friends who are waving us off after a visit.... and then the comments come.
AnswerID: 342791
Reply By: Cruiser Crazy - Tuesday, Jan 06, 2009 at 08:22
Steve,
I put some engine cleaner in mine 2 weeks ago and run for 500Km. The engine doesn't sound that rough anymore, turbo started to "sing" again and a cold start is smother as well. You only have to watch out you don't run with it to long, as it might increase oil consumption.
And I would stay with the 5000km oil change, as the engine gets older and will show some wear and tear around the cylinder.
And I learned last week in a thread here, that if you re-route your breather hose, your occasional black smoke decreases.
Done it, works perfect.
AnswerID: 342806
Follow Up By: Welldone WA - Tuesday, Jan 06, 2009 at 11:35
Cruiser crazy
How and where did you re-route your breather hose to??
FollowupID: 610555
Follow Up By: Cruiser Crazy - Tuesday, Jan 06, 2009 at 11:48
The rubber hose that goes from your rocker cover to the metal pipe connected to your turbo inlet.
I removed the rubber hose and replaced it with a longer one which I mounted in a loop upwards. The turbo creates a vacuum and might suck some drops of oil out of the rocker cover if you have slight overpressure there.
With me, making the loop made a lot of difference.
FollowupID: 610557
Follow Up By: Member - Phil G (SA) - Tuesday, Jan 06, 2009 at 11:55
CC,
Glad that trick worked!
FollowupID: 610559
Follow Up By: Cruiser Crazy - Tuesday, Jan 06, 2009 at 12:02
Thank you for telling me the trick ;-)
FollowupID: 610560
