Goulburn-Oberon Road Query
Submitted: Tuesday, Jan 06, 2009 at 09:30
Member - Terry W (ACT)
Has anyone travelled the
Goulburn-
Oberon Road via Taralga and
Black Springs recently and able to say whether it is suitable for a 20 foot dirt road caravan (Sterling Outback)?
I am getting conflicting advice about the dirt bit from Taralga to the Abercrombie River.
Terry
Reply By: Member - John and Val W (ACT) - Tuesday, Jan 06, 2009 at 09:55
Hi Terry,
Havent been that way for a couple of years but seem to recall that the road around the Abercrombie River is pretty steep and marked not suitable for caravans.
Val.
| J and V
- Albert Einstein
342815
Follow Up By: Member - Terry W (ACT) - Tuesday, Jan 06, 2009 at 10:04
Thanks John and Val. Sounds like the route through Cowra might be the safest way to go. You Northside or Southside?
Terry
610538
Follow Up By: Member - John and Val W (ACT) - Tuesday, Jan 06, 2009 at 10:28
Hi Terry,
The road to Cowra is good, just has some long hills. We are deep north (just over the border in NSW).
Val.
| J and V
- Albert Einstein
610545
Reply By: bockstar1 - Tuesday, Jan 06, 2009 at 10:46
According to this it's now completely sealed;
http://en.wikipedia.org/wiki/Goulburn-Oberon_Road
Regarding the
Abercrombie River NP and
camping grounds. The Sink is accessible by standard car and trailers although there is limited space to set up C/Ts and Caravans.
The Beach and Silient
Creek are more suited to car & trailer/caravan based
camping.
The Beach being the pick of the 2 locations. Access to both these areas is more suited to a 4WD as there are some steeper sections. Access around the southern part of the
park is also more suited to 4WDs than softies and 2WD.
342818
Follow Up By: Time - Tuesday, Jan 06, 2009 at 13:13
In my view anyone who takes a two wheel drive or caravan into Abercrombie NP has rocks in their head!
Re 20 ft van on the tar, you will have problems climbing out of the Abercrombie
River crossing unless you have a heap of power and low down torque, wouldn't recommend it, and as mentioned above it is
sign posted as not suitable for vans.
610569
Reply By: Member - Howard (ACT) - Tuesday, Jan 06, 2009 at 13:11
Terry,
I can confirm that the road is sealed all the way from Taralga to
Oberon.go that way regularly.
what are you towing with as the climb going north up out of abercrombie river has some very tight corners but main problem is it is a very steep pull of a couple of km.
I can get the cruiser hot if I overdo it with the camper trailer on the back.
While the road is not recommended for caravans we have taken 4 decker semi trailer stock floats thru that road when it was still dirt.
not easy but possible.
Howard
342837
Reply By: Gronk - Tuesday, Jan 06, 2009 at 13:23
If I was towing a 20ft van with a manual vehicle, then I would be wary of ever stopping on some of the steep sections, but apart from that, this road is fairly easy.....pick a gear and stick to it and you will have no probs..
342842
Follow Up By: Member - Terry W (ACT) - Tuesday, Jan 06, 2009 at 15:50
Thanks everyone. We tow with an automatic 4.6 litre Disco 2 V8 which has reasonable torque and has low range if really needed. We were just looking for a different route from
Canberra to
Bathurst and it looked like an interesting variation, but we had lots of conflicting advice. I think we will go via Cowra, our usual way, and have a look at the other route without the van.
Thanks again everyone for the great advice.
Terry
610596
Reply By: seawasp - Tuesday, Jan 06, 2009 at 21:04
The road is sealed all the way you intend to travel . Just exercise caution and take your time on the descent and climb at the Abercrombie River , steep and some sharp bends with reasonable turning area. I tow with a L/C 100 and 18' tandem van through this area. Also watch out for the skippies and wombats around night time, we have pranged two Ambulances at
Oberon in recent weeks , there seems to be more around this year.
342941
Reply By: Madfisher - Tuesday, Jan 06, 2009 at 21:23
Another route which is by fat the shortest(260ks Bx to
Canberra) is through
gunning,
Crookwell,
Tuena. The road is now sealed all the way to
Crookwell and only about 12ks of
well maintained dirt left between
Crookwell and
Bathurst.Some steep sections but nothering like the
oberon road, bit windy but interesting scenery and villages.
Cheers Pete
342948
Follow Up By: Middle Jeff - Tuesday, Jan 06, 2009 at 21:36
Hi, this is a great road with lots of history, in it's heyday one of the busiest roads in the country.
Have fun
Craig
610665
Reply By: Member - Terry W (ACT) - Wednesday, Jan 07, 2009 at 14:59
Thanks all. This is a great
forum when you can get such good advice from so many!
Terry
343061
