dual battery set up
Just got a new 4wd any suggestions on the best type of dual battery system I should put in.
Reply By: Member - Norm C (QLD) - Tuesday, Jan 06, 2009 at 21:43
Lots of potential answers here.
The first thing I'd say is it is very easy to do this work yourself. Quite apart from saving a lot of money, the big advantage is understanding your system and being able to modify or fault find it in the future.
The Redarc isolator is an excellent product, well proven and not expensive. I've recently installed one in my new 4WD.
Whether you do the job yourself or not, using heavy enough cable is the key to success. I suspect this is the biggest cause of poor performance in dual battery / 12 Volt systems in 4WDs and RVs.
This Explore Oz article is a good place to start:
Explore Oz Battery Power Article
AnswerID: 342954
Follow Up By: Member - Norm C (QLD) - Tuesday, Jan 06, 2009 at 21:47
Wow, buggered that one up didn't I?
Oh for an edit function.
I'm sure you get the drift and the link to the article works.
Norm C
FollowupID: 610671
Reply By: Member - Mick O (VIC) - Tuesday, Jan 06, 2009 at 21:47
Doc,
Do a search with the search function above. There have been a quite a few recent posts regarding dual battery systems.
Cheers Mick
AnswerID: 342955
Reply By: Wayne's 60 - Wednesday, Jan 07, 2009 at 03:08
G'day Doc,
Can you please supply more information ie
What will you be running off the system
How much room do you have under the bonnet
What type of camping will you be doing.... fixed camping for more than three days or always mobile?
FWIW best to keep it simple.
We have three Bosch Gold batteries, two under bonnet and one in the CT.... not connected.. yet. A small job to rotate the three to keep them in good condition. A simple solenoid system for charging was taken from the 60 and shoe horned into the 80.
Good luck with your project and I hope the information is helpfull
Wayne & Sally.
AnswerID: 342985
Follow Up By: TheDoctor - Friday, Jan 09, 2009 at 00:08
Sorry about that, its my first time on the forums and I was a little nervous. Anyway I have a 2005 Mitsubishi Pajero Exceed 3.2 Turbo diesel. There is plenty of room for the other battery. My intention will be to run an engel and lights whilst fishing and camping. What do you run from yours when your out and about.
Doc
FollowupID: 611157
Reply By: Member - Graham H (QLD) - Wednesday, Jan 07, 2009 at 11:13
The make and model of the 4wd would be a reasonable thing to include in your request.
Otherwise its like trying to do brain surgery over the phone whilst wearing a blindfold
AnswerID: 343024
Follow Up By: TheDoctor - Friday, Jan 09, 2009 at 00:11
Sorry about that Graham, I have a 2005 Mits Pajero Exceed 3.2 turbo. There is plenty room for the other battery. I will be running a fridge lights and what ever else makes a camping trip more comfortable for the wife.
Doc
FollowupID: 611160
Follow Up By: Member - Graham H (QLD) - Friday, Jan 09, 2009 at 09:20
One of my mates has one of these and he had a hell of a job to fit a second battery.
He ended up shifting some stuff and putting an Optima against the firewall on the passengers sidein a cradle he made himself.
I couldnt see anywhere that there was "Plenty of room" for a second battery
FollowupID: 611185
Follow Up By: TheDoctor - Saturday, Jan 10, 2009 at 11:32
Graham last time I looked under my bonnet there was "plenty of room" for a second battery.
All I am after is some suggestions that I can do some research on. I didnt realise forums would be so frustrating!!!!!!!!!!!!!
Doc
FollowupID: 611390
Follow Up By: Member - Graham H (QLD) - Saturday, Jan 10, 2009 at 12:01
They are only frustrating if you dont ask the correct question or fail to provide as much information as possible
Your first question was as vague as they come and as one poster said "Do a search on here"
If you did you would have found countless threads asking the same question and countless answers all with a different opinion.
The article provided by the site gives an insight into the ins and outs of the subject.
Even the difference of whether or not there is room is just the difference between opinions of what is enough and what is not.
I will however check which motor my mates has but it is a 2005/6 Exceed diesel.
Not being rude but had u posted a question like
""I have a 2005 Pajero Exceed diesel and would like to know which dual battery system is best and also what type of battery should i use.""
Something about why you want it EG to run a 80 ltr fridge,etc also helps as to battery capacity etc
You would have got more informative and correct answers.
See what I mean.
FollowupID: 611394
Follow Up By: TheDoctor - Saturday, Jan 10, 2009 at 16:37
Point taken, I will research the above threads.
FollowupID: 611424
Reply By: Geoff (Newcastle, NSW) - Wednesday, Jan 07, 2009 at 21:21
You know, odd as it may sound the best answer to your question is "the system that does exactly what you want"
So maybe if you can tell us "what you want" someone can actually answer your quesion!
Geoff
Geoff,
AnswerID: 343144
Reply By: Member - Luke (SA) - Wednesday, Jan 07, 2009 at 22:17
This set up is what I have in the Patrol, does what I want and all I really need.
Image Could Not Be Found
Cheers Luke
AnswerID: 343155
Follow Up By: Member - Mike DID - Thursday, Jan 08, 2009 at 00:32
Not having a fuse close to the + terminal on the Auxiliary Battery is a fire hazard.
The manufacturer has already provided fuses near the original battery.
FollowupID: 610953
Reply By: Maîneÿ (wa) - Thursday, Jan 08, 2009 at 00:54
You ask : "any suggestions on the *best type* of dual battery system I should put in"
Not to insult you I will suggest a *mechanical solenoid* is inexpensive, so yes will save you some money, but an *Electronic battery isolator* will make you happier, but your wallet lighter :)
The 'best' battery is an AGM Deep Cycle (or two)
Mainey . . .
AnswerID: 343170
Reply By: Member - "The Doctor" (NSW) - Thursday, Jan 08, 2009 at 10:14
G'day Doc,
Can't believe there's another doc out there, I'm stoked!!!
I got a RedArc under the hood of the '06 100Series. Its a beuaty. Very simple to install and very effective.
AnswerID: 343193
Follow Up By: TheDoctor - Friday, Jan 09, 2009 at 00:04
Thanks mate, I will have a look at the RedArc
Doc
FollowupID: 611156
Reply By: Gone Bush (WA) - Saturday, Jan 10, 2009 at 16:54
Doc,
it's not difficult.
Just think of your first vasectomy (or reversal).
You know. You identify tubes (cables) between two kahonies (batteries) and make sure the little taddies (electrons) can run along unimpeded or not.
Now I bet you weren't nervous the first time you hovered over some poor unsuspecting bloke's family jewels with your scalpel.
AnswerID: 343588
