MAF cleaner
Submitted: Thursday, Jan 08, 2009 at 04:56
stefan & 12 times Dakar winner
Saw in super cheap the other day a product for cleaning your MAF sensor. CRC brand or similar?? Anyway was about $25 for a spray can of the stuff. Have you used it? Do you know anything about it? Is it just a can of air?
The Pajero MAF is about $800 so don't really wanna just 'give it a go'
Cheers Stefan
Reply By: Michael ( Moss Vale NSW) - Thursday, Jan 08, 2009 at 06:30
It probably white spirit, X55 or similar, something that leaves no residue. Michael
343172
Reply By: madcow - Thursday, Jan 08, 2009 at 07:21
I wonder how CRC contact cleaner would go? Leaves no residue and even removes fingerprints. It is mainly used on pcb boards.
343175
Follow Up By: Member - Captain (WA) - Thursday, Jan 08, 2009 at 09:07
Its what I used to use on my GU 3.0TD MAF. Very noticeable performance difference after the first clean - but did it regularly after that so no marked improvement later on.
Captain
610973
Follow Up By: madcow - Thursday, Jan 08, 2009 at 12:42
A bit off topic but I also clean the throttle and clutch cables on my bike with it to get the crud out. Sadly the 4.2tdi does not have a MAF sensor :)). Heard of a lot of issues using oiled filters etc causing problems with the sensor.
611001
Follow Up By: stefan & 12 times Dakar winner - Thursday, Jan 08, 2009 at 14:18
"Very noticeable performance difference after the first clean "
Thats the plan Captain, after some reading on the pajero
forum, they reckon you will not know your own car after you do it the first time.
611012
Reply By: Member - Bradley- Thursday, Jan 08, 2009 at 11:28
Yeah , its probably just a rebadged can of contact cleaner, or trico.
I always clean my MAF at every service, and do the throttle body and air bypass valve at the same time, quick and easy to do them all at once and keeps it running like new.
The basic "hot wire" MAF reads the change in resistance across the wire due to the cooling effect of the airflow, so keep it clean and it will read correctly. Dont be scared to give it a go.
343202
Reply By: Member - Glenn D (NSW) - Thursday, Jan 08, 2009 at 13:46
Hi Stefan ,
Isopropyl Alcohol leaves no residue when dry and cleans all the crap off , use a soft bristle brush or a syringe .
Takes a while to dry though, if you cant do it with compressed air.
Would have to get a few litres for $25 ?
Glenn.
343215
Follow Up By: stefan & 12 times Dakar winner - Thursday, Jan 08, 2009 at 14:19
Just a bit cautious of 'touching' the wires. With my luck I would snap one for sure!
611013
Follow Up By: Member - Glenn D (NSW) - Friday, Jan 09, 2009 at 13:28
On the Patrol the sensing elements are a flat plate and a small rod about the thickness of the centre of a disposable pen ( the ink part ) , other types I have seen have the wire inside a glass bulb.
Not sure what te mighty Paj has ,but you would like to think it would be a little robust to sit in the airflow .
611239
Reply By: Louie the fly (SA) - Thursday, Jan 08, 2009 at 20:25
So how do you use it??? Give us the lowdown.
Louie
343273
Follow Up By: stefan & 12 times Dakar winner - Thursday, Jan 08, 2009 at 21:40
will let you know when I get some :)
611125
Reply By: Member - Phil B (WA) - Thursday, Jan 08, 2009 at 21:11
Its actually a CRC product!!
Not a re badged can of ???
343291
yeah had a look on crc website and it seems to be a spray alcohol of some sort.
611124
Follow Up By: Member - Bradley- Friday, Jan 09, 2009 at 16:41
Yep exactly, its one of the oldest tricks of marketing, create a "specialist" product and charge a premium over "generic" products.
I once worked for an oil company and they were magic at it, same batch packed out into numerous different products, from the basic to the specialist.
They did it with detergents too, the same product was everything from general purpose cleaner to floor and tile cleaner to hotplate cleaner and even food grade cleaning product.
I would be highly surprised if its not CRC contact cleaner inside the can.
611275
