A mechanical question
Submitted: Tuesday, Jan 13, 2009 at 10:52
ThreadID: 65077 Views:2883 Replies:3 FollowUps:2
Related Pages
4x4.... off road.... tours parts of Oz [small parts]... so maybe not O/T?
I am yet again replacing my steering box sector shaft for the L2202DT Kubota.
Hit a drain....not too hard really and yet again the teeth snapped on part of the worm drive [sector shaft].
I'm sure that I set everything up snug, tight and in line last time I put the new one in. A suggestion is that there should be stops to prevent the wheels going further than the steering will allow.
Any other ideas?
Reply By: Member - Footloose - Tuesday, Jan 13, 2009 at 11:24
. tours parts of Oz [small parts].....geez that's stretching the imagination a bit, isn't it ? LOL
Hope someone can help, I haven't got a clue. Closest I get is my sit on...hardly on topic.
AnswerID: 344074
Follow Up By: Member - Royce- Tuesday, Jan 13, 2009 at 11:39
Well..... I guess that the definition on 'on topic' is going to be open for definition and that the boundaries are sometimes tested.
By the same token, the 4wd [front wheel assist at least], off road, mechanical parts of the question are still fairly close to the mark. Lots of us are outdoorsy, exploring oz types and I certainly explore with my trusty [hmmm not so trusty] Kubota.
I just ordered the new part and the bloke let on that they had been having problems with a shaft that didn't suit... was 2mm shorter than required...
sure enough, I just compared the other shafts they provided and they are 2mm shorter!
At $300 each that's not nice.
FollowupID: 611953
Reply By: Member - reggy 2 (VIC) - Tuesday, Jan 13, 2009 at 12:12
hi there
most times the stopper is behind the hub near the third arm which is normaly ajustable
hope this helps
cheers reggy2
AnswerID: 344080
Reply By: Member - Malcolm (Townsville) - Tuesday, Jan 13, 2009 at 14:05
Hi Royce
Well it certainly is an off-road vehicle ....
(I know, I have one like it (IIRC L2201 - 2 wheel drive) with slasher - nearly tipped myself into a barbed wire fence when the rear wheel dropped into a hole. I was riding that thing like an outrigger on a yacht getting out of that mess. Still laugh about it to myself - nobody will ever know ;-) ).
6 months ago went out and bought a Kubota L1-R24DT (4x4) with FEL, ROPS, Canopy and slasher. They threw in a towball link and 20 litre sprayer. Just havn't had any time to use the thing yet. Maybe this year sometime.
Malcolm
living the 'good life'
AnswerID: 344098
Follow Up By: Member - Royce- Tuesday, Jan 13, 2009 at 18:18
They are VERY unstable, specially with the FEL raised.
Sounds like your Kubota will be a good buy second hand some day... [little use].
FollowupID: 612023
