Will the hemisphere carrier out of a 78 series fit a 75 series?
Submitted: Wednesday, Jan 14, 2009 at 11:43
ThreadID: 65106 Views:2843 Replies:3 FollowUps:1
G'day all, will a 78 series troopy LSD diff hemisphere carrier fit into a 75 series diff? or are they different also will they fit front & rear? thanks, aussiedingo
Reply By: Member - Tour Boy- Wednesday, Jan 14, 2009 at 13:12
Hi Aussie
Front diffs in the 78-79's are the high pinion as far as I know. A quick call to a wrecker will confirm if the rears are interchangeable in the front and rear of a 75. The axles may be different, the axle studs are larger than the 75's.
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 344270
Reply By: Member - DOZER- Thursday, Jan 15, 2009 at 07:35
No and no.
AnswerID: 344367
Follow Up By: toyotabits.com - Thursday, Jan 15, 2009 at 08:57
thanks for that dozer - sounds fairly definate!
FollowupID: 612333
Reply By: Member - DOZER- Thursday, Jan 15, 2009 at 14:30
The 78 hemi has a different axle spline count to 75 and the ring gear is bolted to threaded holes in the 78, and straight holes in the 75 (bolt with nuts) They run different ratios dependant on motor.
Having said that....you can put the 78 complete diff centre/axles/brakes/wheels on a 75 housing if that housing is disc braked....
Andrew
AnswerID: 344440
