Kimberly Kamper Canvas Removal
Submitted: Wednesday, Jan 14, 2009 at 14:04
Hisko
Anyone had to remove canvas from a Kimberly Kamper? How long does it take etc. I may have to remove to repair damaged zipper on fly door.
Hisko
Reply By: Member - 1/2A - Wednesday, Jan 14, 2009 at 20:05
Can't you just use a pair of long nose pilers to slightly bend in the ends of the slider.
344326
Reply By: Member - julie S (VIC) - Thursday, Jan 15, 2009 at 15:43
Try the pliers on the slider as suggested. We had the same problem with our campertrailer and I was quoted $350.00. We had nothing to loose and it works again. Julie
344456
Reply By: Trekkie (Member - WA) - Friday, Jan 16, 2009 at 01:05
It would be BIG job - I would try to avoid removal at any cost
Maybe a canvas expert may have some type of hand held machine to save removal of canvas ????? -
344540
Follow Up By: billwa - Friday, Jan 16, 2009 at 18:38
We had this problem also. wegot the slider from the canvas place,unoicked the top of the vip replaced the runner and sowed the zip back again it took about 1/2 hr and fixed the problem
612607
Follow Up By: billwa - Friday, Jan 16, 2009 at 18:41
We had this problem also. we got the slider from the canvas place,unpicked the top of the zip replaced the runner and sowed the zip back again it took about 1/2 hr and fixed the problem
612608
Follow Up By: Hisko - Monday, Jan 19, 2009 at 12:17
Thanks all for comments.
Got some help from ladies at work and have successfully repaired the zip. Cut across, removed slider, repaired slider and then slid back on and sewed up small section with fishionf line then applied silicone to repaired section. Like new. Cost ? Three stubbies.
613047
Follow Up By: stephen looking - Monday, Jan 19, 2009 at 12:25
Hisko, you tight ass :) give them a slab for the job, glad you got it fixed mate.
Cheers.........Stephen
613048
