Pajero 2.8l, 4M40 motor - worn turbo advice needed?
Submitted: Thursday, Jan 15, 2009 at 11:02
Member - Oldplodder (QLD)
The old paj's turbo needs replacing, seals going/gone.
Using about 1l per 1000k of oil.
Checked rest of engine and all OK.
Oil in the pipes going to the intercooler.
Turbo has done 330,000k, and is original.
Heavier oil has helped a little, but is only a stop gap measure.
So which make and model of turbo is used?
Talking to a few people around
Brisbane, no can wants to recommend any one to overhaul it.
So maybe buying a new turbo might be the go?
While I am at it, could maybe get something which spools up a little sooner. :o) I tend to drive in the 1800 to 2800 rpm range anyway.
So any thoughts or recommendations, or contacts?
Reply By: Member - Matthew C - Thursday, Jan 15, 2009 at 13:28
Are you sure its not just breathing a little,is the oil on the inlet side of the turbo as
MAtt
344428
Reply By: Member - Nick (TAS) - Thursday, Jan 15, 2009 at 21:34
As Matt said, its not being drawn out the engine breather and re-entering with the intake air.Simple test is to remove the breather hose and put it into a temp. catch can.If you catch oil in it, it compression bypassing the rings and blowing oil out.
I had a couple of turbo's rebuilt by Rota Master in Melb, varied from $600 to $1000, depends on how much is worn.
344507
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Jan 21, 2009 at 21:45
Thanks Nick,
Yes have checked the rocker cover breather, a little oil, as usual but not that much. Must be the turbo.
613411
Reply By: Bob Y. - Qld - Thursday, Jan 15, 2009 at 21:35
John,
There's a mob in
Toowoomba, think they're called Superior Turbos, that appear to have a pretty good name.
They'll turbo anything from a lawn mower to a mack truck! Sorry don't have a phone number.
Bob.
344509
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Jan 21, 2009 at 21:46
Thanks Bob,
Will follow it up.
Think I know who you mean.
613412
Reply By: Shaver - Friday, Jan 16, 2009 at 05:06
There is a bloke on the
Gold Coast called Mr Turbo that does that type of work. Believe he is quiet good. Depends on where you are !
344546
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Jan 21, 2009 at 21:47
Thanks Shaver,
Will give them a ring.
613413
Reply By: Isuzumu - Thursday, Jan 22, 2009 at 07:30
