PATROL 3.0L DRAMAS
Submitted: Monday, Aug 11, 2003 at 21:34
B.P.L.
I recently posted about a problem with my GU. It loses a bit of power (about 10-15%) shortly after the turbo has wound up after each gear change, and then comes back on around 2500rpm. It feels like the computer is telling the turbo to reduce psi for some reaon after boost comes on.
I have spoken to Nissan and now have a new computer and new air flow meter. Still not fixed.
Any other ideas out there?
Reply By: Truckster (Vic) - Monday, Aug 11, 2003 at 21:49
ECU...
27516
Follow Up By: B.P.L. - Monday, Aug 11, 2003 at 22:22
The ECU (computer) has already been replaced.
18937
Reply By: Hugh - Monday, Aug 11, 2003 at 23:52
I have heard that software change (ECU) has fixed this problem. Are you sure that Nissan replaced ECU with latest version? Should be a different part number to the one that was replaced.
Just a thought.
Regards,
Hugh
27535
Follow Up By: Andrew(WA) - Tuesday, Aug 12, 2003 at 00:33
Yep, agree with Hugh. look into whether thay actually changed the ECU.
18948
Follow Up By: B.P.L. - Tuesday, Aug 12, 2003 at 19:09
Yes definately is a new ECU. Has different numbers.
19022
Reply By: Member -BJ (Sydney) - Tuesday, Aug 12, 2003 at 18:45
Put in a D'tronic chip prob goes away . I did.Regards Bob
Where to next
27604
Follow Up By: B.P.L. - Tuesday, Aug 12, 2003 at 19:11
Dyareckon its worth the money because that is one option I was playing with?
19023
Follow Up By: Member -BJ (Sydney) - Wednesday, Aug 13, 2003 at 15:56
It is
mine goessss great. Dont worry about warranty as it piggybacks on original ECU (velcroed on)so if you have trouble just change over plugs & pull it off.Regards Bob
Where to next
19114
Reply By: Andrew(WA) - Tuesday, Aug 12, 2003 at 22:16
BPL
If it still under warranty, don't do anything until Nissan fix the prob.
If not ECU, can only think of the air sensor to cause such a problem but I guess you've been down that path??
I suggest swapping the air sensor with another one from another vehicle which you know runs OK.....
27642
