CB Communicatons
We are wanting to get a two way for our jeep for our caravan trip QLD & NTwhat's the best VHF or HF?? Sorry know very little, would like something that's easy to install and what are the costs? Can we get the guts! Nashy
Reply By: Member - Doug T (NT) - Saturday, Jan 17, 2009 at 09:08
Nashy..........Rambler
You need UHF , not VHF, and for best quality make it a GME brand.
AnswerID: 344730
Follow Up By: Nashy3 - Saturday, Jan 17, 2009 at 09:20
thanks was leaning towards UHF. What is the differences in strength have been told the higher the watts the stronger the signal? Nashy
FollowupID: 612691
Follow Up By: Boobook2 - Saturday, Jan 17, 2009 at 09:47
almost every built in unit is 5W which is the max you can have. Hand helds range from 0.5 W to 5W
Just get 5W
FollowupID: 612694
Follow Up By: Best Off Road - Sunday, Jan 18, 2009 at 11:09
Hey Doug,
Remember the song about the Nash Rambler and the Caddy?
"Beep Beep, Beep Beep, his car went Beep Beep Beep.
Jim.
FollowupID: 612877
Follow Up By: Member - Doug T (NT) - Sunday, Jan 18, 2009 at 11:14
Jim
I see you picked the hint there, yes I sure do....by "The Playmates"
Showing ya age eh
FollowupID: 612879
Follow Up By: Best Off Road - Sunday, Jan 18, 2009 at 11:33
Thanks Doug,
I never knew who sang it or what it was called, but just found it on Limewire and downloaded.
Jim.
FollowupID: 612881
Reply By: Member - Mark G (NSW) - Saturday, Jan 17, 2009 at 09:16
NASHY
i agree with Doug,either a 3220 or a 4400 GME will serve you well.
AnswerID: 344735
Reply By: Boobook2 - Saturday, Jan 17, 2009 at 09:17
Probably neither.
You will probably get most use out of a UHF ( 477mhz) for on the road caravan use for vehicle to vehicle and hand helds. VHF is rarely used now and HF is for specialised long distance and is $3000 plus.
On UHF truckies use channel 40, caravans 18, and 5 for emergency. 40 channels in total.
An in car UHF may cost $300 to $500 fitted and a hand held is $40 up. Range is up to several km line of sight.
If you want long distance for safety etc ( hundreds to thousands of km) then you may want a HF radio. You should get specialist advice if that is what you are looking for. Google vks737 which is one HF service, for lots of info. Big bucks.
AnswerID: 344736
Reply By: Member - John and Val W (ACT) - Saturday, Jan 17, 2009 at 11:05
Hi Nashy,
On LHS of this page there is a searchable "Topics" heading and "Communications" is listed. There is a lot of info on this site to get you started.
As others have said, UHF is for communicating across short distances and is relatively cheap. HF is for long distance comms and costs a bit more - but a great bit of gear for safety if you are heading into remote areas.
Val
J and V
- Albert Einstein
AnswerID: 344748
Reply By: Member - Kiwi Kia - Saturday, Jan 17, 2009 at 12:08
Hi Nashy3, Don't take any notice of people that insist that one brand of UHF radio is the only way to go. I have three different brands of in-vehicle UHF and another three brands of hand helds and they are all roughly the same quality. I would suggest that if you get a hand held then it should be no smaller (power) then 2 watts and the buttons are large enough to work with out needing a magniying glass. I have noticed some good looking second hand UHF radios in places like Cash Converters but you should ask them for a return guarantee that they are working properly.
AnswerID: 344758
Follow Up By: Member - Mark G Gulmarrad - Saturday, Jan 17, 2009 at 14:13
kiwi kia
we only suggest these brands as we can only comment on the performance as we use them.
no use recommending brands we dont use is there?
FollowupID: 612726
Follow Up By: Member - Kiwi Kia - Saturday, Jan 17, 2009 at 17:29
Hi Mark, In case you haven't noticed :-)) there are some people who do more then just recomend, they will tell you not to buy anything else !
FollowupID: 612760
Reply By: Rangiephil - Saturday, Jan 17, 2009 at 15:12
I have a Uniden UH11 . It has worked flawlessly for 17years.
Also have Uniden hand held and it has been great for about 5 years.
Because there is a Federal Government imposed limit of 5watts output power on UHF CB, the performances of various brands are very close to each other. The antenna installation and quality are also important.
Uniden tend to be cheaper than the others and last well. Available Dick Smith and others.
Regard sPhilip A
AnswerID: 344786
Follow Up By: Member - Lionel A (WA) - Saturday, Jan 17, 2009 at 17:05
Is there any reason why power is limited to 5W ?
Cheers.....Lionel.
FollowupID: 612753
Follow Up By: Member - Graham H (QLD) - Saturday, Jan 17, 2009 at 17:21
Its because the lawmakers dont use them, like all the useless unfounded decisions they make.
FollowupID: 612759
Follow Up By: Richard Kovac - Saturday, Jan 17, 2009 at 18:23
Lionel
I hope someone who knows the answer comes along
FollowupID: 612773
Follow Up By: SteveL (WA) - Saturday, Jan 17, 2009 at 22:39
One of the reasons for relatively low power is that they are available to the general public to play with and therefore things rf radiation and rf burns become an issue.
FollowupID: 612809
Follow Up By: Robin Miller - Sunday, Jan 18, 2009 at 08:07
The main reason Richard is to deliberately reduce the range and interference between units.
This originally allowed for more repeaters to be used and provide better local service due to the limited number of channels.
Many are made as 25w units and are supposed to be set for only 5watt e.g. better quality Icom's , but many like some of the Vertex ones can be brought of ebay etc , mostly but not entirely from overseas without being knobbled.
Having 25watt isn't a lot of help in general use , because while you may have a stronger signal , the person your talking to won't be able to get back to you if he still has 5 watts.
FollowupID: 612847
Follow Up By: Mick15 - Sunday, Jan 18, 2009 at 10:55
Also might be to do with the fact that UHF is only really usefull for line of sight communication, so even if you had more watts there would still be limitations to how far it would work.
If everyone had more power it would also make it more likely for you to be listening to everyone elses chit chat as they motored along.
Even an old AM cb can usually outdo a UHF for range, UHF is far better for sound quality however
HF on the other hand can bounce its signal off the ionosphere, making it able to negotiate mountains and the earths curvature.
Probably more important that what brand is to get the right antenna, good quality, mounted and wired correctly, and there really isn't any BEST antenna, despite what some might say, different terrain may favour different gains (for coverage) and construction/length (to last)
If you weren't sure how often you were going to on remote trips i'd say get a decent UHF and just hire a satphone for a trip for safety.
UHF is really only car to car communication, so if you could only have one and were on your own get the satphone!
I like HF but theyre about 1500 for a good 2nd hand one, can also pick up all the AM cb channels with it.
Best to do a decent google search.
FollowupID: 612874
Follow Up By: OzTroopy - Sunday, Jan 18, 2009 at 12:43
Absolutely right Mick15 ..... The best, most recommended, preferred, I had it for years, two way ... hooked up to a cheap, improperly mounted antennae, will probably not work much better than one of those $25 elcheapo handhelds.
Nashy3 .... if your not a radio enthusiast ... stick with UHF over CB ... UHF is now more common in Aust and is what most use. More than adequate for comms on regularly used roads / areas.
CB ( Citizens Band / 27mhz ) is still common in the US as no UHF is offered there for general use (AFAIK) so most jeep articles from the US refer to their "allowable" equipment not Aust - just like the susp mods etc ... For remote travel in Australia - Sat Phones or HF etc give the required safety margin UHF transmission range can never manage.
Lionel A ... 5w output reduces tranission strength and in some cases transmission range - compared to the higher output. Aids in reducing interference signals to others and other equipment.
Of course there is always the situation where the rules applied alweays seemed to be there to stop the masses from communicating with anybody outside their area. Could well be a leftover WW2 attitude that any private person with long range radio gear " had " to be a spy .... lolol.
FollowupID: 612888
