100 series diesel injector cleaning
Submitted: Monday, Jan 19, 2009 at 15:45
Name Not Found
I've done over 200,000 km and would like to have them checked & cleaned as I think my mileage is a bit low.
1. Should I need to do so yet?
2. Can I do it myself and if so is there an online reference to help me do it.
Thanx in advance
Reply By: Member - Tour Boy- Monday, Jan 19, 2009 at 15:54
It is a little more than cleaning, the nozzles will need to be replaced as they wear causing the spray pattern to change. Some of
the springs may also need adjusting.
Then the pressures and spray pattern need to be set on a special machine.
Dave
345079
Reply By: Member - DOZER- Monday, Jan 19, 2009 at 17:00
They are 100000kms over due. Have a diesel
shop do them, save up 900 dollars
Andrew
345086
Reply By: Member - Graham H (QLD) - Monday, Jan 19, 2009 at 18:53
Toyota advise replace injectors and pipes at 150,000.
Why I dont know but thats what the book i have says.
345108
Follow Up By: Member - Matthew C - Monday, Jan 19, 2009 at 22:51
Thats for the factory turbo model 100 series not applicable for the pipes on a 1HZ non turbo.
MAtt
613131
Follow Up By: Member - Graham H (QLD) - Monday, Jan 19, 2009 at 23:08
As the original post didnt state which model thought it may help.
Better than nothing I guess
613134
Follow Up By: Member - Matthew C - Monday, Jan 19, 2009 at 23:15
Graham
Definately mate,more info the better. I would hate to see them replace parts for no reason.
MAtt
613135
Follow Up By: Member - DOZER- Tuesday, Jan 20, 2009 at 00:40
Only the pipes, injecters are serviceable...now if you own a vdj200....theres 8x$1k unserviceable injecters in there....
613143
Follow Up By: Member - Matthew C - Tuesday, Jan 20, 2009 at 13:40
Replaced a heap of them already.
Tourists getting
water in there
fuel and it dont take much to @#$K them either.
MAtt
613184
Reply By:- Monday, Jan 19, 2009 at 19:16
Righto, sounds like a job for a pro then.
345112
