Cannot Login with Firefox
Submitted: Tuesday, Jan 20, 2009 at 18:29
garrycol
Hi All,
I usually us Firefox when I use the
forum and at the moment I am unable to login using it. I can type my e-mail address in the required box but when I put my mouse pointer over the password box nothing happens and as a result I cannot enter my password - it is as if the box is not there. The cursor works with all the other boxes.
Any ideas as I do not like using IE as I am at the moment.
Garry
Reply By: blue one - Tuesday, Jan 20, 2009 at 18:53
garrycol,
Yep some strange things are happening. Every time I open EO it looks like the page is on 150% magnification and I have to scroll around to read it.
Just waiting for it to settle down.
345248
Reply By: Gramps (NSW) - Tuesday, Jan 20, 2009 at 19:08
No problems at all with FF.
Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.5) Gecko/2008120122 Firefox/3.0.5
345252
Reply By: Member - Mick O (VIC) - Tuesday, Jan 20, 2009 at 19:59
Garry,
why don't you send an email to Damian at the Exploroz team. Someone there should be able to give you advice in respect to the problem.
Cheers Mick
345262
Reply By: Member - Geoff C (QLD) - Tuesday, Jan 20, 2009 at 20:17
Same happening to me. Spoke to Damian and he's at a loss too. Nice to know I'm not the only one. Tried all my anti-viru, spyware etc and no change.
Geoff
345268
Reply By: ExplorOz - David & Michelle - Tuesday, Jan 20, 2009 at 20:31
No ideas I must say - I have just tested with FF 1, 2 and 3, IE 6 & 7 and Opera 9 what every version it is and all seem to be working fine. I wonder for yourself and any others that are having a problem what Security product are you using - it would be interesting if all you guys with a problem were using the same one. So which are you using? Can you try loin with it disabled just to see what happens!
I have to point at these products as they all behave differently and cause all sorts of problems. We do not do anything weird at ExplorOz and are working everything all the time to the standards however every darn product implements the standards in a different way.
Let me know how you go. As an alternate use the older
logon system (I will add this to the login drop down tomorrow) but for now use
http://www.exploroz.com/users/exploroz_logon.aspx
DM
345270
Follow Up By: Member - Geoff C (QLD) - Tuesday, Jan 20, 2009 at 20:49
Tried with avg, Zonealarm and Spyware terminator all disabled, still unable to login in FF.
Geoff
613246
Follow Up By: blue one - Tuesday, Jan 20, 2009 at 20:49
Dave,
Logged in as a virgin with no security.
Same issue.
613247
Follow Up By: Member - Geoff C (QLD) - Tuesday, Jan 20, 2009 at 20:53
Tried the link (older login) no change.
Geoff
613248
Follow Up By: Gramps (NSW) - Tuesday, Jan 20, 2009 at 20:55
AVG and Zonealarm running on
mine with FF and no problems at all.
613249
Follow Up By: garrycol - Tuesday, Jan 20, 2009 at 21:20
I have AVG turned off and still cannot log on with FF.
This morning I could log on - this afternoon I cannot. The only thing that I have done was run "Cleanup" today but this is not a new program and I run it regularly. It removes all login information, cookies etc each time it runs so I have to login in again to the forums I use. That was why I was trying to lock back on when it failed. Note I have not had an issue with the approx other 10 forums I use - just Exploreroz.
I did try going back to a restore point from last week but no change.
Garry
613258
Follow Up By: ExplorOz - David & Michelle - Wednesday, Jan 21, 2009 at 10:38
Ok so how do you guys end up logging in (I guess you use IE or something)? Can you tell me exactly what happens when you mouse to the password box and also can you try using the tab key to move between the entry fields to see if tabing in makes any difference.... Please let me know.
David
613301
Follow Up By: garrycol - Wednesday, Jan 21, 2009 at 11:38
David,
Tabbing does not work on the main login screen. While not logged in and trying to enter this followup - the system says I am not logged in and a new login screen comes up which works fine so the issue is the main
forum login screen.
No problems with IE just FF. On the main login screen, the cursor does not move to the password box by either tabbing or by mouse cursor - it is almost as if the password box is invisible to the my computer.
Garry
613306
Follow Up By: Nomadic Navara - Wednesday, Jan 21, 2009 at 17:10
Garry
I reckon it is definitely a problem with your FF installation. Try an upgrade if your installation is not the latest. If still not working then install Foxmrks
http://www.foxmarks.com/ and save your settings on it. Then uninstall FF and re install. Then bring back your settings from Foxmarks.
613355
Follow Up By: garrycol - Wednesday, Jan 21, 2009 at 18:12
Thanks Peter,
Though I am not the only person who is having issues and the problem developed with no changes to my system.
I use FF2 because FF3 has major issues and is not compatible with some other forums I use.
I will do as you suggest with FF2.
Garry
613369
Reply By: Dunco (NSW) - Tuesday, Jan 20, 2009 at 20:54
I couldn't log on by using the login button, BUT I went to reply to a
forum message and a bigger login screen came up and i was able to log in successfully.
If I log out out and try to login by normal methods, I cannot enter my password in Firefox ???
345275
Follow Up By: Member - Geoff C (QLD) - Tuesday, Jan 20, 2009 at 21:08
Tried that, still no login.
Mine is slightly different in that I can input my password but nothing happens when I click login.
Geoff
613253
Reply By: Rolly - Tuesday, Jan 20, 2009 at 21:07
Sorry to be unable to assist.
I have no probs with FF 3.0.5 on an iMac dual core.
Maybe it's another MS Windows problem.
345281
Follow Up By: Rolly - Tuesday, Jan 20, 2009 at 21:19
No probs with Safari either.
613257
Reply By: Brian (Montrose, Vic.) - Tuesday, Jan 20, 2009 at 21:13
I am running latest version of Firefox with AVG free edition and Zone Alarm free on a Windows XP service pack 3 OS and have had none of the above problems today....
345284
Follow Up By: Maîneÿ (wa) - Wednesday, Jan 21, 2009 at 16:05
Running latest 'ff' version, with McAfee, on WIN XP MC edition and service pack 3, with none of the above problems
Mainey . . .
613344
