2nd hand ARB compressor rebuild?
Submitted: Wednesday, Jan 21, 2009 at 19:15
ThreadID: 65313 Views:3969 Replies:4 FollowUps:0
Hi everyone,
I've just picked up a second hand ARB compressor and was after a general idea on whether the pump should be stripped down and checked. It seems to work well at the moment, though I haven't given it a good work out.
Has anyone had to rebiuld their pump?
Were there any areas to be wary of?
TIA.
Wayne.
Reply By: Member - Graham H (QLD) - Wednesday, Jan 21, 2009 at 19:40
Ring ARB there are parts available and they will set you right on what you need if in fact you do
AnswerID: 345407
Reply By: Member - Warfer (VIC) - Wednesday, Jan 21, 2009 at 20:52
I think there is a saying about fiddling with things that are in good working order !
AnswerID: 345419
Reply By: Michael ( Moss Vale NSW) - Wednesday, Jan 21, 2009 at 21:48
Drop one of your tyres to 20PSI and see how long it takes to pump back up to 40psi. i should take about 4-5 mins.. Someone here with a new ARB compressor should be able to tell you exactly how long it takes.. Michael
AnswerID: 345434
Reply By: Max 460 - Thursday, Jan 22, 2009 at 12:36
The ARB compressors are re-buildable.Mine was way down on "power" wouldn't hit the 100psi for pressure switch. I went into ARB and for $52 the sell a re-built kit which has a new barrel, piston, rings, and conrod. Very simple to fit up. Works like new now.
AnswerID: 345496
