Next G phones and external antennas
Submitted: Tuesday, Jan 27, 2009 at 10:19
ThreadID: 65453 Views:6049 Replies:10 FollowUps:5
I have a Samsung A412 and I am wondering how much more effective it would be with an antenna mounted on the bull bar.
This is in preparation for my trip around Highway 1.
I believe Telstra and Dick Smith both supply antennas, any experience if one type is better than another.
Thanks for any advice, as always I appreciate your help.
Reply By: troopyman - Tuesday, Jan 27, 2009 at 10:49
I need one myself
http://store.comnet.com.au/cat/2000942.html
AnswerID: 346138
Follow Up By: troopyman - Tuesday, Jan 27, 2009 at 10:54
I guess the db is important .
For instance read this Site Link
FollowupID: 614107
Reply By: Sand Man (SA) - Tuesday, Jan 27, 2009 at 11:00
Cruiser,
In my experience, your best antenna is one that is tuned for NextG/CDMA frequencies.
This antenna is also suitable for GSM phones as its frequency is not that much different.
The reality is, an external antenna will extend the range somewhat, but in some areas you will just not be in range of a tower.
The location of an antenna is not that much different than that required for a UHF transceiver.
The best place is on the roof line of your vehicle.
The second best choice is the rear left or right corner of the bonnet, providing the top of the antenna is above the vehicle's roof line.
Mounting one on the bull bar, you would need a fairly long antenna and this gives a distinct disadvantage of practicality IMO.
The antenna I have is a Laser brand ground independent collinear antenna with a frequency range 825-890MHz and a gain of 7dBi, mounted on the roof line of the Jack. (Code 509)
I originally purchased this for CDMA phone usage, but as the frequency is the same as NextG, I haven't needed to change.
Around town it is fitted with a 5" stubby rubberised antenna which gives ample reception. Travelling in the country, I exchange the stubby antenna with an 800mm long fibreglass flexible antenna to extend the range somewhat.
Basically, an external antenna will extend the range in marginal locations, but will not give full coverage everywhere.
Much of Highway 1 is reasonably well covered by phone towers, especially along the southern and eastern coastlines, but I suspect there will be many other sections where no coverage at all will be found.
Wouldn't rely on "sound" advice from Dick Smith personnel as they are merely salespeople. The best place for sound advice is a Communications specialist who should also provide a competitive price and installation services if you can't do it yourself for any reason.
Bill.
Bill
AnswerID: 346140
Reply By: Member - joc45 (WA) - Tuesday, Jan 27, 2009 at 11:17
I have a Samsung A411, and an external antenna definitely works a lot better.
Also check out Prestige Communications - they have a 6.5db which covers Next-G 850, GSM900/1800 and 3G 2.1GHz.
The roof is the best place for coverage, but bear in mind its vulnerability - I destroyed my last one from overhanging branches despite it having a spring base.
Gerry
AnswerID: 346142
Reply By: Flywest - Tuesday, Jan 27, 2009 at 11:39
6 Db Glass antenna on th bullbar, recommended by the area manager of Telstra when we were in the Pilbara!
We were in one of the "pale orange" reception areas (marginal) on the Telstra Website reception map.
It meant we could get good recpetion in that area - we for example had another such ariel on the roof of the house and could get 50 kilometers line of sight connection to the Wickham tower, and faster mobile net connections to the internet than via our sattelite connection.
We could get connection all the way from Balla Balla - Whim Creek along highway 1 into Roebourne, Pt Samson, Karratha Dampier etc
Amazingly good system IMHO
AnswerID: 346146
Follow Up By: troopyman - Tuesday, Jan 27, 2009 at 11:42
any links for this antennae
FollowupID: 614114
Follow Up By: Flywest - Tuesday, Jan 27, 2009 at 14:37
http://www.radiospecialists.com.au/antennas%20car%20cell%20phone.htm
[quote]
SG Series Mobile Phone Antennas
The SG series of 6.2dB high gain mobile phone antennas deliver consistent and dependable results where signal coverage would otherwise be marginal.
SG835 is for Next G networks.
SG900 is for GSM networks.
SG890 is dual band for both Next G and GSM.
Yes we stock marine versions also.
[/quote]
Pretty sure this is the same one!
FollowupID: 614137
Reply By: GUJim - Tuesday, Jan 27, 2009 at 12:33
There is another benefit in having a decent aerial connected to your phone - improved battery life. This is only relevant of course if you normally run the phone in the car using it's own battery.
Theory is that if the phone is getting a better signal (from the external antenna) then it doesn't have to transmit at maximum power as often to communicate with the cells as you move.
I have a Samsung A412 also and notice a significant increase in battery life on a country trip when I connect the external aerial.
Improvement may not be as noticable when you are travelling really 'outback'.
AnswerID: 346154
Reply By: Rangiephil - Tuesday, Jan 27, 2009 at 13:02
I had a 7Db CDMA aerial which I used for Next g mounted on a swivel mount on the roof gutter. I often forgot to put it upright and then I broke it off going under an arch. I felt it probably also added a lot of air resistance.
I have replaced it with a small 50MM 4db gain antenna which needs to be in the middle of the roof for best signal propogation to get the 4DB gain. However I think this will be better than the 7Db as the radiation pattern is also wider for hilly country. However you have to drill a 16MM hole in the roof.
If you mount an antenna on the bullbar it will have a very skewed radiation pattern towards the rear of the vehicle. They are the same as UHF CB in this sense. I found that if I was travelling away from the transmitter I could hear the caller but they could not hear my transmission, as my antenna was at the rear of the car.
So I reckon the 4Db on the roof is the better compromise ie on average it will perform as well as a 7Db on a bullbar .
http://www.citytechnology.com.au/microbeam/index.php?main_page=index&cPath=36
Regards Philip A
AnswerID: 346156
Reply By: Member - Mike DID - Tuesday, Jan 27, 2009 at 13:24
Look at the Telstra NextG coverage Maps and they will show you how much more coverage you get using an external antenna -
AnswerID: 346160
Follow Up By: oldtrack123 - Wednesday, Jan 28, 2009 at 22:09
Member - Mike DID replied:
I was going to say something about the accuracy of Telstra coverage maps , but with themod on the forum today I'l just be quite
FollowupID: 614449
Follow Up By: Member - Mike DID - Thursday, Jan 29, 2009 at 21:34
These coverage maps are only accurate if you have a good phone and a good antenna - I find them quite accurate.
FollowupID: 614669
Reply By: Member - Norm C (QLD) - Thursday, Jan 29, 2009 at 21:51
Cruiser, we use the same phone. We have an RFI CD 2195 Antenna on the bull bar. It is a 6.5db antenna and is available from many Telstra shops for around $100. It is an excellent antenna and gives vastly improved range.
You will also need a patch cord that plugs into the antenna cable with a small plug that matches the phone. Often available at Telstra shops, or available from a lot of places on the net. I think I paid about $15, including postage from a web based shop.
All works very well and we have had phone and internet access in some surprisingly remote spots with this set up.
Norm C
AnswerID: 346650
Reply By: Von Helga - Sunday, Feb 01, 2009 at 08:52
Cruiser,
I was with a mate on the Murrumbidgee near Mt Selwyn where he was getting reception to call home with his vehicle mount broomstick antenna.
I was so impressed that I brought the same set up from "Cellit" on eBay for $129 incl patch cable and Z mount bracket delivered to Canberra.
On a recent trip with my wife we were at Sawyers Hut in the Snowys with no reception on her stand alone mobile with Telstra and I had 2 bars of signal on my mounted telstra phone and made a call home with no probs.
I have no idea of its specs but it will do me.
BTW
I have the situation where I have a garage for my truck but in the past I have had to remove various antenna elements to get the car in to it.
The phone antenna brought the same problem back so I turned the Z bracket upside down and bolted it to the bull bar antenna mount and then but the antenna on the Z bracket which effectively lowered the antenna by about 100 mm which allowed it to fit under the roller door.
AnswerID: 346990
Reply By: Axel [ the real one ] - Sunday, Feb 01, 2009 at 09:43
Our aerial mounted on bullbar ,MobileOne ,MaxiGSM , 3G/GSM-7db ,,
increases signal strength on average by 2 bars .IE: phone signal showing only 1 bar will jump to 3 bars when plug in aerial , ,, also use same for wireless broadband on laptop ,
AnswerID: 347003
