Squeaky Treg
Submitted: Monday, Feb 02, 2009 at 16:58
ThreadID: 65641 Views:6340 Replies:15 FollowUps:5
Our Treg coupling squeaks like mad whenever we turn a corner - except when it is wet.
Short of having one of the kids hang out the back of the car giving it a squirt now and again what is the best lubricant for these things.
I have been reluctant to experiment in case the rubber deteriorates or the lubricant attracts dust - any help would be appreciated.
IanM
Reply By: SPRINT-GTO - Monday, Feb 02, 2009 at 17:03
Couldnt hurt to try LANOTEC--natural lanolin lubricant.
AnswerID: 347264
Reply By: Notso - Monday, Feb 02, 2009 at 17:08
You could also try a smear of plumbers rubber grease. Although I think the blocks are polypropylene aren't they? Anyhow I don't think the rubber grease would do any harm except attract dust.
AnswerID: 347267
Reply By: Member - Alastair D (NSW) - Monday, Feb 02, 2009 at 17:16
I use spray on White Lithium grease. It dries quickly and is not sticky to attract the dust and grit.
alastair
AnswerID: 347272
Follow Up By: Tim - Stratford (VIC) - Monday, Feb 02, 2009 at 18:49
"....White Lithium grease.." - Me too - best thing I've found so far - and it smells pretty good too!
Tim
FollowupID: 615441
Reply By: Member - MUZBRY(Vic) - Monday, Feb 02, 2009 at 17:17
Gday Ian
I would try a dry lubricant, like graphite dust.
Murray
AnswerID: 347273
Reply By: MEMBER - Darian (SA) - Monday, Feb 02, 2009 at 17:18
Cheap spray can of Silicone - $6 (Bunno's).
AnswerID: 347274
Follow Up By: Michael ( Moss Vale NSW) - Monday, Feb 02, 2009 at 21:45
Darian has the answer $6 can of silicone spray.. And the block is made of PU. Michael
FollowupID: 615470
Reply By: handy - Monday, Feb 02, 2009 at 17:18
inox or wd 40 wont hurt the rubber block. cheers
AnswerID: 347275
Reply By: Member - Teege (NSW) - Monday, Feb 02, 2009 at 17:41
Ian
I used to use a silicone spray - Inox or similar. Sprayed on the pin. I found it also made the pin a lot easier to slip into position when camped in awkward locations where it was hard to line it up properly. (No longer have a camper - so no more Treg coupling)
teege
AnswerID: 347280
Reply By: DIO - Monday, Feb 02, 2009 at 18:01
Lanotec (lanoline) spray will not damage the rubber block and it WILL eliminate the squeaking noise.
AnswerID: 347285
Reply By: Member No 1- Monday, Feb 02, 2009 at 18:08
soap?
AnswerID: 347286
Reply By: MAVERICK(WA) - Monday, Feb 02, 2009 at 19:06
i have had my 7x4 trailer since 1992 and it has done a lot of things and been to many places over many many kms but never has the treg hitch squeaked - in fact it has never made any type of noise. you may have a problem with the connection not being square or 'true'. you should not need to spray anything on any part and need only to grease the shaft. they are not a rubber block but a poly material block - at least my red one is so unless they have changed........ there is no harm done anywhere if you do spray but check everything is lined up properly first. rgds
AnswerID: 347293
Reply By: GerryP - Monday, Feb 02, 2009 at 20:18
Hi IanM,
I have seen where the brass tube actually separates from the polyblock and can spin or move around, in fact, this has happened to me as well. While it's easy to check the tube which you put the pin into, the other fixed (horizontal) one is a bit harder to check as the pin is generally spot welded in place. This problem can be made worse by a highly loaded WDH on a caravan as extra loading is put on the block.
Might pay to just make sure all is well in this department as the tube may be moving in the block and giving you that squeak. If so, I'm afraid it will need replacing. Blocks can be purchased separately from Treg.
Gerry
AnswerID: 347302
Reply By: A J - Monday, Feb 02, 2009 at 20:59
Ianm (Vic) we used Selleys Eziglide for all our dry lub needs - does not collect dust - used on zips on canopy in dusty conditions with success.
A J
AnswerID: 347307
Reply By: Richard Kovac - Monday, Feb 02, 2009 at 21:58
Ian
buy a Troopy you will never hear it...
Richard
but I do like the above responses I will add then to my list..
AnswerID: 347319
Reply By: Member - Roachie (SA) - Monday, Feb 02, 2009 at 23:13
Just slightly off topic but a timely warning in any case...........
Apparently, some time ago, a young fella (ie: teenager or around 12 to 13), was assisting his dad to hook up the camper. Dad was at the wheel, young bloke was given the job of adjusting jockey wheel up and down and getting the hitching process completed. The block was almost spot-on in the right position, but about 1/4 of a pin diameter out of position. Young bloke decided to poke his finger down the hole to try to align. BIG MISTAKE!!!
He still has 9 fingers and is highly unlikely to lose another one from another misadventure of this nature!!!
Roachie
AnswerID: 347335
Follow Up By: handy - Tuesday, Feb 03, 2009 at 06:52
yeah he wont do it again. i jam the little clip pin behind the block to keep it straight. cheers
FollowupID: 615508
Follow Up By: Axel [ the real one ] - Tuesday, Feb 03, 2009 at 08:30
OUCH , makes the eyes water just thinking about it ,
FollowupID: 615518
Follow Up By: Member - Oldplodder (QLD) - Tuesday, Feb 03, 2009 at 09:21
Saw a young apprentice do the same thing erecting some steel.
Finger in the hole, no more finger.
That's what podgers are for.
FollowupID: 615525
Reply By: Member - Oldplodder (QLD) - Tuesday, Feb 03, 2009 at 09:23
Use lanolin spray to touch up on the road.
Also have some lanolin grease by the same mob.
Put some on before the trip.
A lot easier to hitch up too.
AnswerID: 347355
