Coleman Hot Water
Submitted: Sunday, Feb 08, 2009 at 10:21
ThreadID: 65796 Views:2476 Replies:1 FollowUps:6
I picked up one of their units at Rangers(WA) for $299 this week.
On special till stocks last.
Fired it up last night and it is brilliant. Time to throw those old solar bags in the bin: )
Reply By: Member - Warfer (VIC) - Sunday, Feb 08, 2009 at 14:31
Hiya Ross
Do yourself a favor and fling that sh^&*tty bit of what they call a showerhead over the back fence lol for the likes of what i bought at bunnings..Also replaced that hard hose for something a bit softer. (sailing shop)...
Image Could Not Be Found
AnswerID: 348158
Follow Up By: ross - Sunday, Feb 08, 2009 at 14:42
LOL I did get roped into buying the shower head. Im going away next week end,so I may just use it opnce;)
FollowupID: 616368
Follow Up By: guzzi - Sunday, Feb 08, 2009 at 16:54
Preheat the water into a bucket and just use the unit as a pump when you shower, otherwise you'll spend 80% of you water trying not to freeze or scold yourself.
Otherwise a brilliant unit.
FollowupID: 616394
Follow Up By: Shaker - Sunday, Feb 08, 2009 at 18:53
We have never had a problem setting the water temperature.
FollowupID: 616419
Follow Up By: Axel [ the real one ] - Sunday, Feb 08, 2009 at 21:13
guzzi ,, if you have a problem with the water temp control ,easy fix is to take off the control knob[ philips no1 screwdriver] remove spring and replace knob ,,, easy as and water temp control much user friendly.
FollowupID: 616447
Follow Up By: Member - Warfer (VIC) - Sunday, Feb 08, 2009 at 22:19
***Preheat the water into a bucket and just use the unit as a pump when you shower, otherwise you'll spend 80% of you water trying not to freeze or scold yourself. ***
Hiya Guzzi
You sure your units working correctly,seams to defeat the whole purpose to preheat...I usually wait till its warmish (will never freeze, the hows your fathers lol) to hop under and i hav marked the heat i like with a texta...Take the knob off is good idea too..I only use for shower..
FollowupID: 616473
Follow Up By: ross - Monday, Feb 09, 2009 at 00:15
The test I did the other nighr indicated the control knob was doing its job.
FollowupID: 616490
