Location of pipe on Roof-Rack
Submitted: Tuesday, Feb 10, 2009 at 22:06
Member - Warfer (VIC)
Hiya
Hopefully you guys that have these on your racks will be able to tell me the best place and the best way to attach them...In the pictures i have three spots ranging from 1 to 3 .Three being my best choice.
Rhino hav end caps,are these worth it or just get the screw ones from plumbing supplies
Image Could Not Be Found...
It will be 100mm pipe.
Reply By: Dave B ( BHQ NSW) - Tuesday, Feb 10, 2009 at 22:29
G'day Warfer, I think I would go for 3 as
No 1 would restrict what you can tie tightly to the edge of the rack I think, and also cut down on fully usable space in the rack.
No 2 in my opinion would probably also make it difficult to tie things down on the rack because of the pipe being hard against the top rail.
No. 3 I would also leave a bit of room to thread a rope through between the pipe and the base of the rack too, just in case you want to tie down something through there.
I always use plenty of ropes on a pack rack because of the wind resistance and you don't want anything moving.
Also if you have a tarp that's flapping around, you will use up heaps more
fuel than if you have a
well tied down tarp. You don't want a tarp looking like the spinnaker on Australia 2.
Dave
348528
Reply By: That Troopy Bloke (SA) - Tuesday, Feb 10, 2009 at 22:38
Quote "Rhino hav end caps,are these worth it or just get the screw ones from plumbing supplies "
That's an easy one to answer
No caption needed.
Glenn
348532
Follow Up By: Member - Teege (NSW) - Wednesday, Feb 11, 2009 at 06:57
Glenn
I have prevented that problem by cutting a piece of 4" high density foam to size (slightly oversize actually) and forcing it in each end of the pipe. Got the foam from the local recycling centre - it started out life as as a foam cushion. With that in place there is no movement and I use the plumbers screw on ends.
teege
616749
Follow Up By: Member - Warfer (VIC) - Wednesday, Feb 11, 2009 at 19:24
Thanks Glen
616830
Reply By: The Rambler( W.A.) - Wednesday, Feb 11, 2009 at 01:08
My choice would be no.1 which is where Ihave
mine.Iam sure if Ihad put
mine in 2or 3 it would have been ripped off going through scrub and under tree branches.
348544
Reply By: Richard W (NSW) - Wednesday, Feb 11, 2009 at 06:38
Warfer,
Mine are in position 2 as there is not enough room for 3. Used stainless steel hose clamps to mount them. Been on two vehicles over 7 years with no dramas.
348546
Reply By: Member - Matt & Julie (VIC) - Wednesday, Feb 11, 2009 at 07:49
Hi Warfer
Ours is the same as 1st choice, had no problems, if you
want to see send us an mm as we live at McCrae, we also
put foam each end of the pipe.
348547
Reply By: Member - Keith C (NSW) - Wednesday, Feb 11, 2009 at 07:59
G/day Warfer, Maybe one on each side of a smaller dia.,will fit inside the legs? , Are you using it for rods,tent poles,
water?if it`s for rods you will probably need 100mm, then it would be option 3 I think .What ever you use make sure it`s uv proof. I think you can get screw on ends that will take a small padlock.
regards Keith C
348548
Reply By: Wayne (NSW) - Wednesday, Feb 11, 2009 at 08:30
Warfer,
I have been using roof rack pipes for many years and have found this method works for me.
On the long pipe that I have I have used 4 clamps and on the short pipe 3 clamps, don't skimp on the clamps.
If the pipes are too high it is very hard to get the end cap on and off. I stand on the rear step on the Troopie to get easy access to the pipes
I have used both the Rhino screw end caps as
well as the plumbing supply one. Make sure you have a cable to stop the end caps from getting lost.
I have a pipe on both sides of the roof rack. Short poles on one side and long poles along with UHF and HF aerials on the other side. I am working on eliminating the short pipe soon.
I used short sections of roof rack bars "Uni Strut" and bolted them to the side of my roof rack. I was then able to use the pipe clamps to secure the pipe to the Uni Strut.
Rhino Rack have roof bars that have the same cross section as Uni Strut, you could use this bar as it would be more readily available.
Rhino Rack would also have the pipe clamps.
Wayne
348551
Follow Up By: Member - Warfer (VIC) - Wednesday, Feb 11, 2009 at 19:06
Thanks for the pics and explanation wayne !
Cheers mate
616826
Reply By: Member - Warfer (VIC) - Wednesday, Feb 11, 2009 at 19:07
Thanks to everyone for there advice and pictures,I will look at all options..
Thankyou very much...
348626
