A magnetic compass has a bar magnet floating or balanced....
Submitted: Sunday, Feb 15, 2009 at 20:41
ThreadID: 66014 Views:8429 Replies:8 FollowUps:22
So... how does a magnetic compass work?
What does the "N" stand for?
If the North Pole of the planet Earth attracts the "N" of the magnetic compass then it should be the south pole of the needle.. No?
Reply By: qubert - Sunday, Feb 15, 2009 at 20:49
its only marked 'n', but truely the south 'end' of the needle . opposites attract
AnswerID: 349268
Follow Up By: Member - Royce- Sunday, Feb 15, 2009 at 20:51
Yup... my understanding.
FollowupID: 617498
Follow Up By: Member - Royce- Sunday, Feb 15, 2009 at 20:53
But then.... what happens if you hang a bar magnet from a piece of string. Does the "N" point north?
FollowupID: 617499
Follow Up By: Bonz (Vic) - Thoughtfully- Sunday, Feb 15, 2009 at 22:39
waffle qubert, totally wrong
FollowupID: 617535
Reply By: blue one - Sunday, Feb 15, 2009 at 20:53
Royce,
A compass "N" will point to magnetic north. Check on the web for the current deviation to true north.
AnswerID: 349270
Follow Up By: Member - Royce- Sunday, Feb 15, 2009 at 20:54
Okay... so the little needle is a small magnet. Is the 'n' the north of the magnet or the south pole?
FollowupID: 617500
Reply By: Member - Royce- Sunday, Feb 15, 2009 at 20:53
AnswerID: 349271
Follow Up By: Member - Graham H (QLD) - Sunday, Feb 15, 2009 at 21:35
What is your point As long as one end points north.
It depends on the maker possibly.
They probably stamp N on it to confuse people, but others will accept that it probably points north.
Usually on a compass the points are on the case not the needle which quite often is in the shape of an arrow so why worry.
If you can see the sun you can work it out yourself.
I had a watch that had a compass function built in and it didnt have anything on the hands and I cant remember which one always pointed north.
FollowupID: 617511
Reply By: Member - Kiwi Kia - Sunday, Feb 15, 2009 at 21:36
The 'N' stands for - The North seeking pole.
As it is attracted to the North pole of the earth's magnetic field it must actually be a South pole.
AnswerID: 349284
Reply By: troopyman - Sunday, Feb 15, 2009 at 21:44
I looked up how to make a compass in jack absaloms safe outback travel . You only need a stick and the sun .
AnswerID: 349286
Follow Up By: heldus - Sunday, Feb 15, 2009 at 22:18
or an analog wrist watch and the sun ....
Helga
FollowupID: 617525
Follow Up By: Member - John and Val W (ACT) - Sunday, Feb 15, 2009 at 22:33
Ooops my reply below should have been here!
J and V
- Albert Einstein
FollowupID: 617533
Follow Up By: The Explorer - Monday, Feb 16, 2009 at 01:16
or a GPS..
FollowupID: 617559
Reply By: Sigmund - Sunday, Feb 15, 2009 at 22:13
The whole planet is like a bar magnet, and the compass needle (on a bushwalking or protractor style compass) aligns with lines of magnetic force which run roughly N-S.
AnswerID: 349298
Follow Up By: Member - John and Val W (ACT) - Sunday, Feb 15, 2009 at 22:32
If you know the time you can use your imagination to visualise the face of an analogue watch. Point the 12 to the sun and north is roughly half way between the 12 and the hour hand.
Val.
J and V
- Albert Einstein
FollowupID: 617532
Follow Up By: Member - Royce- Sunday, Feb 15, 2009 at 22:51
If you place two bar magnets side-by-side then the N is attracted to the S and visaversa.
Is this alignment?
The 'n' is attracted to the Earth's opposite pole? No?
Not sure what alignment is. Is it like some sort of lines of attraction?
FollowupID: 617544
Follow Up By: Member - Kiwi Kia - Monday, Feb 16, 2009 at 07:15
Royce the 'N' does not stand for 'North'. It stands for 'North Seeking'.
FollowupID: 617576
Reply By: Rosco - Qld - Monday, Feb 16, 2009 at 14:29
Imagine the Earth as a giant magnet with the lines of longitude representing the Earth's magnetic field. A compass needle is also a bar magnet which aligns itself with the Earth's magnetic field. With magnets, opposite poles attract, hence it is actually the south pole of the compass needle which points to the north. To avoid confusion the south pole is marked as the north (usually painted red).
Similarly with a prismatic compass which only has the north marked.
AnswerID: 349363
Follow Up By: qubert - Monday, Feb 16, 2009 at 15:36
thats what i said at the start but no one listened
FollowupID: 617628
Follow Up By: Rosco - Qld - Monday, Feb 16, 2009 at 15:42
exactly ... ;-)
FollowupID: 617631
Reply By: Flywest - Monday, Feb 16, 2009 at 16:13
Yebbutt.
In addition too - the magnetic south pole of the needle being painted red and marked N (for north pole seeking) - theres another important feature to make suure you get right these days (with buying stuff off the internet!).
Those rogaining / hiking type needle compasses - typically the silva brand etc, are actually made for use either in the northern or southern hemisphere, seldom both.
The difference is where the balance point of the "needle" is.
The tendency of attraction causes the balance point of the needle (i.e. pivot point) to be placed either toward the magnetic south pole of the needle or toward the magnetic north pole of the needle, from its equidistant centre natural balance point, depending whether the compass is manufactured for use above or below the equator!
This is particularly so with marine compasses which usually have a marked circular compass card.
Large Vessels (Ships) that regularly traverse the equator have specially adijusted compasses built specifically for that purpose.
I once saw this "difference" in a pair of seemingly identicle "silva' compasses, one I owned andanother owned by a US based university student on a shool trip downunder.
She had the same compass as me - but bought and ised in the USA!
When placed alongside each other, the difference in needle pivot points was quite obvious, (maybe a quarter inch) and hers - made for use above the equator, the longer Red (South Magnetic Pole of (needle) dipped so strongly that it dragged on the backing plate of the compass when it was held level and affected where it pointed.
Unless you see the two alongside each other - it's a difficult concept to grasp fpr some.
When you buy a compass off the internet - be SURE you specify a "southgern hemisphere" model if you plan on using it here in Oz
Lastly.
When converting magnetic readinsg to "true" readings in order to mark a route or plot a position on a chart, you need to take into account TWO alterations to the magnetic bearing
1st is Variation
2nd is Deviation
Variation is shown on the compass rose printed on the chart nearest your position, and is often expresed as somthing like, 0 degrees 1.5 minutes + (or -) 15 seconds per annum.
This means you need to look at the date of the printing of the chart - take the printed Variation and add or subtract the amount of annual variation to get a figure, for that point in time, and either add or subtract it from your magnetic bearing.
Then.
You shpould also have a compass devation chart for your particular compass - made by your compass adjuster. t tells you how much out your specific compass is in each of 8 or more directions around the compass card, to compensate for devation within your compass caused by nearbye metallic and electrical cables etc in your vehicle / vessel.
It can be + or - also depending which direction your travelling and the particular setout of your vehicle / vessel.
These two figures are added or subtracted from your magnetic bearing to get a true bearning to plot on your chart (all charts are aligned to true orientation not magnetic which does move slightly each year! (Due to the earths equinoctial precessionary movement or wobble about it's north south magnetic axis).
The "aid memoir" used by navigators to remember what to do with the 3 figures (magnetic, varation & deviation) is thus:-
True Virgins Make Dull Companiions
T (True) chart
V (Variation)
M (Magnetic)
D (Devaitaion)
C (Course) to steer
Lastly for those who have trouble finding their way in the dark due to the lack of the sun & a watch to determine direction, without a compass.
Learn to identify the Southern Cross star formation in the sky (if it's cloudy your screwed). Usually you can see this by finding the two pointer stars (alpha centauri & rigel kent) and then look for the familiar 5 star grouping predominant on ours and the kiwis national flag.
These group of 7 stars (the pointers & soutrhern cross) orbit about the south pole.
If you take your two fingers (index and middle) on your right or left hand and extend your arm full length such that index finger points at ONE of the stars of the long axis of the southern cross and the other finger poiints at the OTHER of the two stars that form the long axis of the southern cross,
you can then "extend" that long axis distance by 2 and a half times, in the direction away from the two pointer stars, drop an imaginary line vertically down to meet the horizon and that point should be due south!
Best of luck - personally a GPS is a great tool - specially one with a fluxgate compass built in and they aren't that dear these days!
Be aware tho that GPS CAN be fooled with, bye those who control the satelites - such as in times of warfare, such that the results they give are NOT accurate!
A compass & chart are good backup if you suspect your GPS is on the fritz!
GPS is really only a backup to good compass and chart work - it should confrm your manual calculations, rather than be your primary navigation tool.
They are so good these days most people rely on them 100% (including myself most of the time).
2 occasions spring to mind where GPS proved to be wrong.
Occasion 1
Gulf War 1 - US invasion of Iraq under stormin Norman Schwartzkopf, commenced when I was offshore in a boat from WA's southwest Cape (Hamelin Bay).
We headed out past the island in a southwesterly direction keeping the cape on our left.
The invasion started when we were fishing / drifting with the GPS switched off!
We started up to come back and could see the cape to the east of us.
The GPS showed our direction to travell as heading SOUTH toward antarctica, while we KNEW - we had to go north coz we could see hamelin Island and the Cape!
We did what we KNEW we had to do not what the GPS showed..
We sailed north back to Hamelin Island end then the boat ramp in Hamelin bay - our chart plotter showed us traveling further and further south past Ausgusta!
The miliary in the USA deliberately altered the data being put out by US Domestoc GPS sattelites, so that their enemy couldn't use GPS guided munitions against them.
Occasion 2.
In September 2001 I was attending a navigation school in Perth on the Evening (here) of 9/11 attacks against the Twin Towers in NYC!
I had a newish Garmin hand held GPS with a couple waypoints saved from Nannup in the southwest 300 km's south of Perth, and another waypiont from Dirk Hartog Island at shark bay some 600 kms north of Perth.
When I set a "go to" command for the Nannup waypints the needle tracked me north of perth towards waneroo
When I set the go to command for the Shark bay waypoint the needle tracked me SOUTH of Perth.
Again US military altered the data for domestic sattelites in the hope tha it would thwart any further use of GPS guided auto pilot settings so no more passenger planes would fly into US strategic targets!
It appears to me at least that they reverse the north south data readings.
SO theres a couple examples when - you couldn't rely 100% on
GPS as so many of us do these days.
I ddi read of one more problen with sattelite clock data - where a computer that was restarted by a nasa tech was re booted with the wrong clock time and thus gave bad positioning data for a few hours putting a few domestoc jets 200 kms off the east coast, when they thought they were tracking on auto pilot for Sydney!
IF - you have a good innate "feeling" for manual navigation (and confirm it in vehicles with certain expected landmarks from the maps along the way) or at sea take bearings fixes to plot waypoints on your chart, THEN if your GPS does go on the fritz for whatever reason - hopefully you will wake up to the mistake before it takes you somewhere you don;t want to go...
Worse of you get to the wrong place only to realise you have insufficient fuel to get back to where you intended to be!
At sea - we allow 1/3 fuel for getting there 1/3 for getting back and 1/3 for contingencies (bad weather , beakdowns, lost etc!).
Might be a good suggestion for 4wd's in remote crossings situations!
Best a luck!
AnswerID: 349372
Follow Up By: Rosco - Qld - Monday, Feb 16, 2009 at 18:11
Interesting post there .. very informative.
Thanks .. ;-)
FollowupID: 617649
Follow Up By: Member - Kiwi Kia - Monday, Feb 16, 2009 at 18:29
Hi Flywest, I would challenge any compass user to tell the difference between a northern or southern hemisphere device !
Other then variation all the other factors are insignificant as long as you are not sitting on a large electromagnetic device.
I disagree with your assertion that if you were rogaining you could tell the difference between a northern or southern hemisphere compass. Even at sea or in the air you could never hold a continuous course much better then + / - about 5 degrees anyway. Wind & current drift or turbulence will need to be corrected and your track made good will be a series of continuous corrections as you 'chase the needle'.
FollowupID: 617653
Follow Up By: Member - Tony S (WA) - Monday, Feb 16, 2009 at 23:42
Flywest,
That would be the same as :- Drawing an imaginary line though the long axis of the cross, then disect the pointers half way, at 90degrees and where the two lines meet, that is true south.
The rig
FollowupID: 617709
Follow Up By: Member - Tony S (WA) - Monday, Feb 16, 2009 at 23:45
Sorry, not well put however I think you know what I mean.
Tony
The rig
FollowupID: 617710
Follow Up By: Flywest - Tuesday, Feb 17, 2009 at 00:54
Thanks - I do try!
For Kiwi Kia's benefit.....I prefer not to debate those who disagree with me - thats your prerogative - eveyone should be discernig of what they read on the internet IMHO and try to conform the info from independent sources if they are at all doubtfull.
[quote]An interesting detail is that there are northern- and southern-hemisphere compasses. This has to do with the fact that the magnetic field lines, to which a compass needle aligns, point into the earth at the north and south magnetic poles. In the northern hemisphere the north end of the needle is pulled downwards, and the south end is counterweighted to balance the needle. When you use a northern hemisphere compass in, say, Australia, the south end of the magnet is pulled downwards by the magnetic field, and is also heavier than the north end - resulting in a needle that catches and drags on the bottom of the compass housing when the compass is held horizontal.
[/quote]
Source: - http://bushwalk-tasmania.com/forum/viewtopic.php?f=15&t=1258
[Quote]
Compass Zones
In order to get accurate readings from a compass, the needle must be balanced in the vial so that it does not drag. Due to the components of the Earth’s magnetic field, a compass that works in the United States will drag or stick in Brazil. To remedy this problem, the compass industry has developed five compass zones (see zone map below). Here is a list of the major countries in each zone.
Zone 2: Mexico, Central America, Panama, Columbia, Venezuela, Northern Africa
Zone 3: Peru, Bolivia, Brazil, Central Africa
Zone 4: Paraguay, Uruguay, Southern Argentina, New Guinea, Southern Africa
Zone 5: Australia, Antarctica, New Zealand
[/quote]
Source: http://www.labsafety.com/refinfo/ezfacts/ezf313.htm
And so it goes!
As it happens the lass from the USA who had the zone 2 silva left it with me when she left to go home, so I now have the pair to compare (in storeage at the moment) so for anyone in WA who wants to physically "compare the two side bye side, I'll do my best to get them both out of storeage, next time i'm down in Mandurah at the storeage shed.
I seem to recall the Bream fishing commuity went thru a series of problems with auto pilot electric outboards of the Monn Kota variety - when they First were mported into Australia!
Being made in Japan for the American bass fishing tournament fishers - it came with a zone 2 compass card, which here in Oz = would "stick/rub on the backing" - and simply couldn't drive a straight line as a result!
Many were sent back under warranty before "someone at Minn Kota in Japan "finally twigged" that the built in compass in tyhe unit was at fault.
Once fixed the Minn Kotas now are favourites with a Lot of Aussie bass fishers!
Theres a LOT more to compasses than many realise....
That was the point of my post!
Re holding course and ignoring devation and only applying variation - well lets just say i wouldn't have passed navigation doing that, - maybe in a 4x4 fair enough but not at sea!
Yes you also have to correct for set and drift at sea as well in offshore nav, but then you would also be using a sextant to get your declination etc, and thats a whole lot harder nav than coastal with just variation and deviation to contend with over the shorter distances involved .
The "test" chart for Nav exam is the whitsundays off Queensland - because there are so many magnetic anomalies to contend with as well as a LOT of islands and shoals etc, which will REALLY sort out the wheat from the chaff in manual navigation, due to the complexity.
That one chart has 3 different compass roses printed with 3 different variations all within some 30 odd nautical miles or so - due to the influence of such things as magnetic island etc!
I couldn't in all conscience suggest anyone ignores magnetic deviation and just alows for variation, UNLESS - the compass deviation chart has very minimal values for that specific compass.
There are some that are quite accurate - my own compass in my vessel is ONE of the few that seems to not require any correction the last time the compass adjuster tested it - I got a "nil" deviation result in 8 directions which s quite unusual according to the adjuster.
In a scenario like that - well of course one can ignore deviation.
It's less likely to get that in a 4x4 because theres so much MORE ferrous metal (my boats aluminium hence non ferrous) and electronics and theres less deliberate design to keep such sources away from compass mounting positions.
On land - if your good at your land marks and positioning - then deviation mightn't be of much conecern - whereas at sea there are few if any visible landmarks on occasion, to continually correct
course, so over longer distances and a course madeup of several different legs - the error is compounded in magnitude with increasing distance.
In plotting such courses usually a clearance of 1 Nm is allowed to major obstacles......now it doesnt take a LOT of compounded position errors thru ignoring deviation on a compass that has large deviation in some directions to end up on rocks or worse at night.
On land the same might be true for example in a long distance desert crossing where all dunes begin to look alike...
It's horses for courses.
If for example you don't understand deviation or variation and are contemplating a long remote dessert crossing, relying on just GPS?....... maybe a couple days tuition in nav mightn't go astray if things turn bad and the GPS is on the fritz for whatever reason.
Going back to long distances at sea and set and drift correction.
These corrections can be large, in areas with large tidal movements, strong winds, and large sea state condtions (sea & swell).
One trip 54 Nm across to the Houtman Abrolhos off WA's mid west -I plotted a manual course out of Geraldton Harbour - aiming to go about a mile north of Beacon island at the Wallaby group and into little pigeon Island. After about 50 miles - using the manual course, (and watchng the chartplotter) the conditions were so bad we were 6 Nm south of Goss passage - instead of 1 Mile north of Beacon Island - due to set & drift, requiring reverting to the second course I'd plotted up thru Goss Passage and around to Little Pigeon!
Of course it's easey with a GPS - but doing it the old fashioned way by compass and time / speed, takes a LOT of skill and practice & attention to detail.
It's best to stay familiar with the manual method and use the GOS for convenience - asstated beforetheGPS is really only to conform what you already know it SHOULDN'T be your primary means of navigation.
Letting my number 2 son take the helm (to avoid him getting seasick - it works) was in part responsible for our large set and drift error, but at least I KNEW thathe wasn;t following the plotted course close enough - had a backup course plotted in case - and then still had the GPS chartplotter as the final check to get us there safe n sound which I did!
Its does show you tho - just how important it is to get it right at sea, - land nav tends to have a LOT more land marks along the way to confirm your position a lot more frequently and correct any cross track error (set & drift) as it occurs!.
Bad steering alignment, a dragging brake pad etc (dunes at a tangent to the desired direction of travel) all might tend to effect the ability of a 4wd operator to steer a straight course in offroad conditions in the dessert.
Any practice you can get is worthwhile IMHO as ot much beats practical experience.
Hitting an offshore island the size of a needle in a haystack, 50+ miles offshore is hard enough even with modern GPS asistance.
Finding a fuel dump in the middle of the dessert with no roads to guide you might be almost as hard!
Now surveyors - they are a breed apart, likely they will get you there to within a centimeter or two - just that it will take all bloody week for them to do it right!. LOL
FollowupID: 617717
Follow Up By: Member - Tony S (WA) - Tuesday, Feb 17, 2009 at 01:27
Actually Flywest I think there are three ways of obtaining true south.Your description, mine and another one.
But there again you know what thought, thought!
Must go into the accuracy of the various methods one of these days.
Tony
The rig
FollowupID: 617719
Follow Up By: Member - Kiwi Kia - Tuesday, Feb 17, 2009 at 06:51
Hi Flywest. I could also present you with a dissertation on things like the 'dip' (Z component) on a compass needle but that is just being blinded by science theory. I also have passed exams both theory and practical in navigation. I think you also need to read carefully the original questions and points of interest that have been presented. Yes, the northern hemisphere compass will work with no problems in the southern hemisphere. The 'dip' will be negligible the closer you get to the equator. If the compass has been manufactured properly to allow for dip (ie there is room for the needle to tilt) then dip will not be a problem. Your example of a compass having problems with the needle scraping is a design fault in that brand of compass. And, as I originally stated "your track made good will be a series of continuous corrections as you 'chase the needle'". Note the words "continuous corrections" I never said that you will choose a direction and 'nail it' as of course you will be at the mercy of the wind, tides, the natural perturbation's of the vessel or aircraft (eg 'Dutch role") and of course 'the hand on the wheel'. I have spent many an hour on the darkest of nights following E type compasses (not old enough for the 'P' type), RMI, DI, ADF, VOR and various other types of compass, compass aids and direction finding equipment.
FollowupID: 617721
Follow Up By: Flywest - Tuesday, Feb 17, 2009 at 14:27
Hi Kia
[quote]
Yes, the northern hemisphere compass will work with no problems in the southern hemisphere. The 'dip' will be negligible the closer you get to the equator. If the compass has been manufactured properly to allow for dip (ie there is room for the needle to tilt) then dip will not be a problem. Your example of a compass having problems with the needle scraping is a design fault in that brand of compass.[/quote]
Not a design fault at all - just a case of a northern hemisphere compass being used well south of the equator (34 south).
Silva aren't necessarily a 'bad compass' by design - IF they are used for where they are designed for.
The fact the southern hemisphere "Silva" counterpart worked perfectly is ample proof of that.
The "problem" with the Northern hemisphere one was as you and I have both described - there was insufficient room within the damped liquid space for the needle to accomodate the amount of tilt required to get the needle not to drag on the backing plate.
Yes - using it nearer the equator might well have required less tilt and thus made it serviceable - but I can assure you that at 34 south, we could not achieve that!
Interestingly - insted of counter weighting the needle as much of the literature describes, the particlar pair of Silva compasses, described appeared instead to have moved the pivot point to achieve balance.
The length of needle protuding past the pivot point was opposite on the two comasses, by a visually veiwable amount when compared side by side! Maybe only a couple milimeters, but visible non the less.
It made for an interesting discussion for the US University Anthropology students, who I was leading on walk along the Bibulmun rack on the day, who had never seen or heard f the phenomoenon of northern and southern hemisphere compasses before then.
I happened to have a garmin hand held E Trek Summit, with built in fluxgate compass as well, for comparisons.
The Garmin interestingly had some difficulty getting and holding sattelite signals under the 70 - 90 % tree canopy foliage covering, and it wasn't until we cross a powerline clearing that I was able to get a "fix" to confirm our then known (by the powerline/track crossing) poisition.
I was able along the way however to locate a shield tree with the CALM (now DEC) Grid Co-ordinates emblazoned upon it which also confirmed our position en route.
There are a LOT more ways to confirm position in land nav than sea nav in my experience.
Air Nav I don't want to know about - its hard enough in 2 dimensions - 3 dimensional nav must be a nightmare!
But the original question was about magnets and compasses and the earths ley lines.
With any luck - som members are now more informed than they were!
And - with regard to finding south......make that 4 ways - doesn't the moss grow on the south side of tree trunks in kiwi land? ;o)
FollowupID: 617760
Follow Up By: Member - Kiwi Kia - Tuesday, Feb 17, 2009 at 17:23
Hi again flywest,
We are almost on the same wave length or line of flux :-)) but I can assure you that I have used many a compass (hand-held and fixed) direct from Nth America at higher then 45 degrees (and further) south with no reel problem with dip, just tilt a little and it's all ok. You mention flux gate compass - these are designed to avoid problems of deviation so you needn't bother about it. Even with an old power hungry HF radio almost next to a compass I have never seen a deviation card with more then + / - 4 degrees which is still within the lower limit that a person can actually steer without an autopilot.
FollowupID: 617780
