mud tyers or standard
Submitted: Wednesday, Feb 18, 2009 at 20:01
ThreadID: 66083 Views:3173 Replies:4 FollowUps:2
Related Pages
i have allways run two sets of tyers allterains and in winter would put on muds when 4wd in eastern vic.will do same with new car but as only done 15000kl what would be a better tyer for some sand driving have been told that standard tyers are better.my next trip will be a simpson crossing .any opinions
Reply By: Robin Miller - Wednesday, Feb 18, 2009 at 20:26
Always been of the opinion that 1/2 worn mud tyres or good open AT is best for Simpson.
I find real issue isn't Simpson but its access roads.
Think I've done it maybe 1/2 dozen times , 4 out of 6 times the Birdsville track has been muddy around middle of year, usually encounter a car thats rolled in a mud slide.
AnswerID: 349736
Reply By: Bonz (Vic) - Thoughtfully- Wednesday, Feb 18, 2009 at 21:38
Robin is on the money, if its only the sand you are worried about then virtually any tyre at 18-15 PSI will be fine, but the access roads will take some toll on road biased tyres. I would go all terrains all the time anyways for general use. I run Cooper STT's and they are great, quiet on road and awesome offroad.
Mate had almost stuffed road tyres on his GU when we did Fraser Is and they were fine.
AnswerID: 349756
Reply By: MrBitchi (QLD) - Wednesday, Feb 18, 2009 at 23:26
If your muddies are too aggressive they can be a hindrance in sand 'cause they can dig in too readily. An at or road tyre is better, but as others have said, you need to think about getting there and back. Personally a good set of AT's would be my choice.
AnswerID: 349793
Follow Up By: _gmd_pps - Thursday, Feb 19, 2009 at 01:32
I second that. Here in WA it's mostly sand and AT is the way to go or a solid truck tire. Air down and off you go. Muddies dig .. not really that great in sand .. and loud on the road
good luck
gmd
FollowupID: 618087
Reply By: Richard W (NSW) - Thursday, Feb 19, 2009 at 17:27
Warren,
Had two sets of rims, steel and alloy. Replaced the original AT's with muds on the alloys and put the old AT's on the steels.
Now on the second set of muds and recently got rid of the steels with the AT's as I never used them after I put on the muds. I find the muds pretty good in all conditions. Done Stockton plenty of times with the muds at 16psi and had no dramas.
AnswerID: 349906
Follow Up By: Member - warren G (VIC) - Friday, Feb 20, 2009 at 07:02
thanks for all replys will get a set of ats on new rims and wait to road tyers wear ot then put mudies on cheers warren
FollowupID: 618315
