replace a 2.8 nm paj motor for a 3.2 DID
Submitted: Friday, Feb 20, 2009 at 17:48
ThreadID: 66142 Views:2840 Replies:3 FollowUps:2
hey all, my nm paj has hit 300.000klm,getting a little worried about it's reliability now,would love to find out if i can fit a 3.2 DID to replace the 2.8, can anyone help me out with knowledge of this being done or if this conversion should work, its a 2000mod,manual nm, thanks all.
Reply By: Member - Oldplodder (QLD) - Friday, Feb 20, 2009 at 18:20
Like you my paj has hit just over 300,000k, had to get the motor rebuilt because of a cracked head. Looked into using a 3.2.
Mine is the older 96 NK with 2.8, but similar issues.
From what I found out on various forums, a few people have done it.
Issues and notes I found out, well the major ones.
The 3.2 block is basically the same as the 2.8, so engine mounts fit OK. Evidently the same bolt pattern on the bell housing and a similar gear box.
The 3.2 is double cammed, so you can't fit the intercooler over the engine. Move intercooler to the front and replumb. Mine is top mounted, not sure of the 2.8 in the NM.
The 3.2 uses a computer controlled version of the same 2.8 bosch rotary fuel pump, so you need to swap the wiring loom over from the 3.2.
Install an electronic throttle from the 3.2, due to to the item above. You loose the manual throttle control pull out.
Think there will be some other issues such as fuel lines and fuel filter location.
So it is not completely impossible. :o)
I would try the victorian pajero web site for more info.
Hope that helps.
AnswerID: 350110
Follow Up By: Madfisher - Friday, Feb 20, 2009 at 18:30
Scott their was a lot of info on the Vic Paj club on this as one of their chaps put one into a series 11.
Cheers Pete
FollowupID: 618433
Reply By: scott71 - Friday, Feb 20, 2009 at 18:41
great,thanks for that,i'll now hunt down the vis club and check that out,im looking at buying a damaged 2001 paj with 3.2 at 95000klm on clock,so if the main areas-bell house-engine mounts are the same im happy to muck around with the rest,my nm being the same shape as the 3.2 fited 01 mod id geuss its not to much of a ask to fit the 3.2 the hit a auto elec to sort the rest for me,,again thanks for the help.i'll keep watach on this thread,as i need to be sure before in grab this damaged paj,
AnswerID: 350113
Follow Up By: scott71 - Friday, Feb 20, 2009 at 18:43
sorry for bad spelling in that,cant type to good!
FollowupID: 618435
Reply By: Members-Neil & Margie-Cairns - Friday, Feb 20, 2009 at 21:23
G'day scott ,,
345000 km on ours and still going strong , from what i have been told , these are a very strong and reliable motor , so when the time comes i will be rebuilding it ,, hasn't been touched as yet and hope it lasts a fair while !!
All the best , Neil ..
AnswerID: 350148
