Keyless entry remote programming for 04 Cruiser
Submitted: Saturday, Feb 21, 2009 at 19:09
Pelks
I bought a new Keyless entry remote for my 04 HDJ79RV Landcruiser and want to program it for my car. I don't really want to go to a dealer to do it. Have hunted around the net and there seem to be many different types of programming methods. Have tried a few but they dont seem to work.
Does anyone know how to do it?
Reply By: Member - Warfer (VIC) - Saturday, Feb 21, 2009 at 19:13
Hiya Pelks
What brand is it ???? Look on the net in your area for Car Alarm Installers,You can find ones that will come to you..
Once installed (not sure if its diesel) and you want to put Turbo Timer you need it wired properly..
350293
Follow Up By: Pelks - Saturday, Feb 21, 2009 at 19:16
Its an original Toyota remote with a single black button and red led at one end.
618586
Follow Up By: Member - Warfer (VIC) - Saturday, Feb 21, 2009 at 19:26
You should hav got some instructions,I know the main unit plugs in under the dash where your right leg is somewhere...Did you get instructions at all ??? As i said a Car Alarm installer should be able to do it...You could always ring Toyota for a quote first...
618587
Follow Up By: Member - Warfer (VIC) - Saturday, Feb 21, 2009 at 19:31
Sorry Pels disregard my comments i misunderstood your question,thought you were adding new keyless system to vehicle...Sorry
Being an extra transmitter i know some key
places in Shopping Centres do Holdens and Fords but not sure about Toyotas..
618589
Reply By: Lex M (Brisbane) - Saturday, Feb 21, 2009 at 19:24
see post 32750
link to 32750
350297
Reply By: Member - Warfer (VIC) - Saturday, Feb 21, 2009 at 19:35
Giv these guys a ring in your area..
Mr Minit
350298
Reply By: Andrew-rodeo - Saturday, Feb 21, 2009 at 21:40
1. Obtain all remotes for the car.
2. Drivers door open, and key removed from the ignition switch.
3. Lock the vehicle using a programmed remote
4. Within 20 seconds.
- Unlock the door uning the programmed remote
- Insert key into the ignition
- Switch the ignition from off to on making sure it is in the off position on the 20th turn.
5. The indicators will now flash 20 times and you are in the programming mode.
6. On the 20th flask push the button of each remote you want to programme.
7. Switch ignition on to exit programming mode.
350320
Follow Up By: Member - Graham H (QLD) - Saturday, Feb 21, 2009 at 22:21
When u do the 20 on and offs U MUST COMPLETE IT WITHIN 20 secs or it wont work
So do it bl++ry quick
618626
Reply By: Pelks - Saturday, Feb 21, 2009 at 23:23
Thanks everyone for your replies. I'll give the 20 times solution a go tomorrow. I'll let you know if it works.
350329
Reply By: Pelks - Sunday, Feb 22, 2009 at 09:32
Thanks Andrew-rodeo, for your solution. It worked a treat.
350362
