Sunday, Aug 17, 2003 at 23:10
G'day Andrew,
ERPS from ARB depends on how many (contact) points you get with the system. Most ERPS outlets recommend 4 contact points for a 4WD Wagon the size of a Prado or a Jackaroo - and 6 or more for a Patrol or Landcruiser. I went for 6 on the Prado cause I knew it would be up
the beach a lot. Cost me about $600 from memory - but worth every single damn penny!
Lanotec comes in 1Ltr cans at about $22 each, without a spray unit - and can be sprayed on with a regular garden spray unit (like you would use to spray the weeds in your garden). It's very easy to apply - apply it liberally to all underbody parts on your 4WD, then about 4 days later take her for a short spin (10 K's or so) on a dusty dirt road. Lanotec is sticky - so it picks up the dust and creates a layer on the bottom of your 4WD which helps to prevent salt intrusion.
Even after all these measures - I avoid driving through salt
water whenever possible. And I always wash the Prado before and after going to one of our gorgeous Sandy areas (such as Fraser Is. or Moreton Is.).
Hope this helps. Any more Q's let me know and I'll help out as best I can.
19557
