towing in overdrive
Submitted: Tuesday, Feb 24, 2009 at 07:30
nowimnumberone
gday we just bought a maverick auto and was wondering what the go is with towing in overdrive.we used to have a jackaroo auto and towed in overdrive without any problems.or is it a big no no with the niissan
thanks very much.
Reply By: Best Off Road - Tuesday, Feb 24, 2009 at 07:39
Can't answer your question Jim, but did you get Petrol or Diesel?
Jim.
350712
Follow Up By: nowimnumberone - Tuesday, Feb 24, 2009 at 18:29
gday jim
me being a tight a** i got a duel
fuel
619108
Reply By: Willem - Tuesday, Feb 24, 2009 at 08:45
I thought mechanics had all the answers.
Maybe you should ask one....lol
Jackaroo's are the lighter of the two so with the the Nissan/Mav it should be OK to tow your CT in O/D. Just change down if the old bus struggles.
350718
Follow Up By: nowimnumberone - Tuesday, Feb 24, 2009 at 18:31
thanks willy.
only the good ones
do you know any lol
look out now i can come away and annoy you
619109
Reply By: ross - Tuesday, Feb 24, 2009 at 08:57
There has been a hundreds posts on this subject.
It really depends on the load,the inclines and the vehicle.
There is lots of sob stories from owners of all makes of 4wd who have damaged transmissions towing in 5th.
Err on the side of caution
350720
Follow Up By: Motherhen - Tuesday, Feb 24, 2009 at 18:03
Spot on
ross
619104
Reply By: Member - Richard H (NSW) - Tuesday, Feb 24, 2009 at 09:13
I towed a 18 foot Jayco van with both a Td5 Disco & a Toyota Hilux. Both were auto transmission & diesels.
Usually if I tried towing in overdrive the transmission oil light came on. The Disco had a good transmission oil cooling sysytem too.
Dick
350721
Reply By: Maîneÿ (wa) has - Tuesday, Feb 24, 2009 at 11:09
I also tow in overdrive with an auto diesel
Get an *EXTRA* TRANS OIL COOLER installed
Keep the engine running in max *torque* range
Mainey . . .
350741
Follow Up By: nowimnumberone - Tuesday, Feb 24, 2009 at 18:32
thanks thats going to be the first thing i do.
same as i did to the falcon
the last owner just had it serviced it and has filled it with synthetic auto fluid.
619110
Reply By: Madfisher - Tuesday, Feb 24, 2009 at 13:57
Run with the power button on,as soon as you need to put your foot down it will change down.
cheers Pete
350768
