Barrett 550 programming software
Submitted: Tuesday, Feb 24, 2009 at 10:07
ThreadID: 66243 Views:5789 Replies:3 FollowUps:4
I have just bought a Barrett 550 which I want to set up for marine use.
Does any one know where I could acquire the necessary software to make this possible?
Taking or sending the set to a dealer is probably not feasible in this part of the world so any help would be appreciated.
I've looked at the demo software for the 900 series. Unfortunately while the software prints to file it does not appear to address the serial port.
I have the manual including tech drawings for the set so have been able to fabricate a programming lead.
I would really appreciate any help.
Many thanks.
Reply By: Topcat (WA) - Tuesday, Feb 24, 2009 at 11:15
As I have mentioned in a previous post, Barrett software is under copyright so you will not be able to obtain it legally. You will need to take your set to a licenced dealer to have the work done. Cheers
AnswerID: 350743
Follow Up By: martindevoy - Wednesday, Mar 04, 2009 at 07:42
Thanks for your reply.
Barrett is a make not well known in the UK but I'll check with Barrett to see if they have a dealer in this part of the world.
FollowupID: 620306
Reply By: Member - Mark E (VIC) - Tuesday, Feb 24, 2009 at 11:56
I might be able to direct you to an appropriate place for re-programming...depending upon where you are.
markeaustatbigponddotcom
Mark
AnswerID: 350750
Follow Up By: martindevoy - Wednesday, Mar 04, 2009 at 07:44
Barrett is not as well known here ( I'm based in the UK) as it ought to be but I'll check with Barrett to see if they can help.
Martin
FollowupID: 620308
Reply By: charlie horse - Wednesday, Feb 25, 2009 at 10:08
The 550 software runs on Windows 3.xxx. and a slow computer.
It can present problems if you load it "too quickly" I had to get a new Eprom about $100 plus freight when it was damaged.
Give Barrett a ring in WA and I am sure they will be able to help.
AnswerID: 350941
Follow Up By: martindevoy - Wednesday, Mar 04, 2009 at 07:47
The 900 software also is written for Windows 3.xx and appears to have been constructed in Visual Basic.
I have Java and Visual Basic programming experience and perhaps I should contact Barrett to see if they want the software updated.
Martin
FollowupID: 620310
Follow Up By: charlie horse - Wednesday, Mar 04, 2009 at 08:17
Thanks Martin,
If you have any luck, I would like to get the ability to program my 550
Chris
FollowupID: 620314
