Prado 120 series Dual Fuel and towing fuel Consumption
Submitted: Sunday, Mar 01, 2009 at 18:10
Member - Carl S (VIC)
Just need some idea what drivers of this car are getting when loaded up without towing and loaded up and towing?
I would appreciate honest figures, since leaving
Melbourne (and really cheap
fuel) my figures are as follows
Average speed 100kph and not towing Petrol 18 litres, gas 22 litres per 100.
Towing at consistant 90 KPH Petrol 23/24 litres per 100 and Gas 27/ 30 litres per 100
Have had car serviced with new filters, new plugs tyre pressures at 38psi, roof rack with
camping gear and a 17 foot Jayco pop top, now I know Diesels are better but this consumption seems very excessive and expensive at 99 cents per litre for gas(sometimes $1.16!!!)
Does this mean trade in time for a T/D???
Reply By: Dave Thomson - Sunday, Mar 01, 2009 at 18:22
Carl I agree, I've an 02 3Ltr T/D and pull a 17 Ft Freedom and I average 14 Lts per 100 K's towing and nearly 10 ltr per 100K;s not,
I know the petrols use more but that does seem excessive , have you took into account hills, wind against you etc ?
regards,
Dave
351726
Follow Up By: Member - Carl S (VIC) - Sunday, Mar 01, 2009 at 18:41
Hi Dave
thanks for that, Every Diesel owner I come across tells me similar figures, what I really need is dual
fuel figures, For most of this trip the wind direction has been favourable, using 4th gear and cruise, "D" is useless and I do appreciate the fact there is a fair bit of weight, Used to own a 3 litre Gu and was getting 18 towing and 13.5 not towing, only bought the dual
fuel because of cheap Melb prices, Dual
fuel certainly serves no purpose up here in the Territory!!!
619924
Reply By: George_M - Sunday, Mar 01, 2009 at 18:39
G'day Carl
I'm with Dave on this one. I drive a 4L petrol, and on the highway (without a roof rack) I get just on 13L/100klm. This is at a pretty constant 100kph - rarely any faster.
If you're getting 18L/100klm under the same conditions, you'd better start with your friendly neighbourhood Toyota dealer...
George
351732
Follow Up By: Member - Carl S (VIC) - Sunday, Mar 01, 2009 at 18:44
Tried that George, everything has been serviced or replaced, their last response was injector cleaning, I use injector cleaner all the time, at a real loss here
619926
Follow Up By: George_M - Sunday, Mar 01, 2009 at 19:23
Ok - the next step could be to have a look at
this site.
There's sure to be someone who's had a similar issue with a dual-
fuel Prado 120 series - about the fifth topic from the top.
George_M
619944
Follow Up By: George_M - Sunday, Mar 01, 2009 at 19:25
...I'd better try "whose" rather than "who's" - you get lazy when you use a spell-checker:-)
619946
Follow Up By: Member - Carl S (VIC) - Monday, Mar 02, 2009 at 10:20
Funnily enough, I am a member of Prado point, and have had numerous reply's, but I thought I would try this
Forum to see what others had to say, am getting back a different response which is good,
620026
Reply By: Madfisher - Sunday, Mar 01, 2009 at 18:51
Carl I take it is an auto?How many Ks has it done? It does seem excessive, most 4l are quite good on
fuel.Also check with Prado piont web site lots of info their. We own Jacks which are generally more thirsty then 120, but even our auto is better then that.
Check your air filter, get your maf cleaned, try a 10/40 oil in the cooler weather, and try running premium(takes a few tanks for computor to readjust) The premium
fuel will clean injectors etc leading to and increase in efficently.
Cheers Pete
351739
Follow Up By: Member - Carl S (VIC) - Monday, Mar 02, 2009 at 10:23
Thanks Pete
already been on Pradopoint, the oil may not suit the top end, but I will have a look at the Carbon cannister and MAF, Toyota dealers just don't want to know!
620027
Reply By: lunchbuckett - Sunday, Mar 01, 2009 at 21:57
carl ihave a 1999 playdo dual feul on gass towing a 23.5ft winsor 2300kg with 75ltr s gets me in perfect conditions 311 ks not loaded i get 415 ks hope this helps .
351784
Follow Up By: Member - Carl S (VIC) - Monday, Mar 02, 2009 at 10:24
Thanks for that, and you have the smaller motor, will have a go a the motor myself, Maf sensor and Carbon canister
620028
Reply By: Member - Fred B (NT) - Monday, Mar 02, 2009 at 12:09
I am very interested in the above as I too run a 4ltr prado.
OK, for the mechanically uninitiated (me), what's a MAF?
351838
Follow Up By: George_M - Monday, Mar 02, 2009 at 14:08
Hi Fred
Have a look
here.
I think the Prados use a "hot wire" MAF, but don't quote me on that.
MAF's are critical to
fuel efficiency, are relatively easy to get at and clean with contact-cleaner, but are VERY delicate.
George_M
620039
Follow Up By: Member - Fred B (NT) - Monday, Mar 02, 2009 at 19:29
Thanks for that, Wiki (in this case) provides a very clear explanation.
620093
Reply By: Madfisher - Monday, Mar 02, 2009 at 16:40
mass air flow sensor= m a f . I believe the prados use a wire also,
Carl what about the oxygen sensor in the exhaust? Normally last about 150000ks.
Could be worth while checking out 2.25 in exhaust as
well, have head they make a diff.
Good luck Pete
351874
Follow Up By: Member - Carl S (VIC) - Tuesday, Mar 03, 2009 at 11:02
Had fun getting to the MAF sensor, some clown at Toyota had over tightened the 2 nuts on the engine cover and 1 nut would not come off, just spinning around, anyway cleaned the MAF was a bit dirty, all put back again, double dosage of injector cleaner, tyres at 38psi and off to
Darwin, will see if there is any improvement
thanks for everyone's help
620176
