Primus portable cooker ?
Submitted: Thursday, Mar 05, 2009 at 21:54
ThreadID: 66548 Views:3128 Replies:8 FollowUps:4
Hi all,
Heading to Dunn's track over the weekend, will be camping the one night.
Rather than pack the stove, stand and gas bottle for the sake of a couple of meals and billy boil ups was thinking of purchasing one of them little Primus single burner stoves that use the butane canisters.
Not having ever used one before are they up to the job or simply a toy ?
Cheers.....Lionel.
Reply By: Lex M (Brisbane) - Thursday, Mar 05, 2009 at 22:05
Work OK for what they are. Just be careful not to cover the whole top of the unit so the gas canister overheats. It can forcefully dismantle the stove.
AnswerID: 352423
Reply By: Member - Ron M (NSW) - Thursday, Mar 05, 2009 at 22:07
Lionel
Having been in the same situation before. I think you would be better off with a small gas portable bar b cue that you can cook , boil and even toast in the morning . You can buy them in their own bag and they do now take up much space
Ron MACKENZIE
AnswerID: 352424
Reply By: Shaker - Thursday, Mar 05, 2009 at 22:49
They work very well, the only common problem is they can be a little slow on a cold morning.
AnswerID: 352438
Follow Up By: Rolly - Thursday, Mar 05, 2009 at 23:08
So slow that, in temperatures below 0°C, they can cease to function. An old hikers' trick is to warm the canister under your clothing, warm up some water with the small amount of gas available before the butane freezes again and use that heated water to keep the butane canister warm whilst boiling up your stew.
FollowupID: 620646
Follow Up By: Shaker - Thursday, Mar 05, 2009 at 23:12
if we are above the snow line here, we just put the cylinder in our sleeping bag, nice warm cylinder in the morning!
FollowupID: 620648
Reply By: Dave(NSW) - Thursday, Mar 05, 2009 at 23:45
Be careful what you stand it on, They will put a burn mark on a wooden table so I found out.
Cheers Dave...
GU RULES!!
AnswerID: 352450
Reply By: tarpon - Friday, Mar 06, 2009 at 01:37
Take a look at Coleman fold and go stove. Small, compact, and takes small coleman propane cylinder, so totally portable.
At least this way, you are getting far more efficient burning, cooking etc.
Food for thought....
Regan.
AnswerID: 352457
Reply By: Best Off Road - Friday, Mar 06, 2009 at 06:29
Lonel,
They work well as long as the weather is warm. I find they perform poorly on cool mornings, say under 10, and are near useless under 5.
For the $20 they cost, a single burner screw on top for your existing bottles is a better option IMHO.
Jim.
AnswerID: 352465
Follow Up By: Shaker - Friday, Mar 06, 2009 at 09:38
Jim, They are good, but hopeless in the wind, at least with the other type the plastic box on edge doubles as a wind guard, & he is only talking about 1 night.
FollowupID: 620679
Follow Up By: Member -Signman - Friday, Mar 06, 2009 at 11:37
Just position it on the leeward side of the vehicle !!
FollowupID: 620715
Reply By: BFreer - Friday, Mar 06, 2009 at 11:11
Living in the cold country, can verify the non-performance of butane canisters during cold weather, however you can get 80% butane 20% propane canisters (the same brew as in the Coleman canisters) for the little Primus stoves - they work really well in cold weather and although costing about 20 cents more than straight butane they put out more heat and don't freeze up in the cold - the local outdoors shop in Armidale carry "elemental" High performance Butane 80%/Propane 20% canisters for about $8 per 4 pack, (elemental website - www.gmagencies.com.au) and I understand that GasMate also put out a 80/20 canister. All the el-cheapo packs are 100% butane. Hope this helps
AnswerID: 352502
Reply By: get outmore - Friday, Mar 06, 2009 at 16:46
cant believe these negaive replys
Lionel-take it from someone who uses them in the same climate as you do - you will never pack a gas bottle again
best $20 you will ever spend work best with cast iron frypan which retains heat
AnswerID: 352587
